Community Member
How to tell which side ended a call
I'm trying to log on a syslog server mainly which side initiated a request to end a call on an h323 gateway.  I would run that continously and save it.  What's the best debug command for that?  I don't want big long outputs such as q931 if I can avoid it.  Just something short and concise.  I was hopping it was in
%VOIPAAA output on the router, but unless I'm missing something, it's not in there.
Thanks in advance for your input.
1 REPLY
Hall of Fame Super Gold
Re: How to tell which side ended a call
Try conf t
aaa accounting connection h323 start-stop group radius
gw-accounting syslog.
If that doesn't do for you, try cch323 debugs.
207
