How to test ground-start analog lines?
Hello, we have ground-start analog lines connecting into our gateway and believe there is an issue with one of the lines.
Is there any good way to test ground-start analog lines?  With loop-start lines I simply use an analog phone to test if an analog line is either good or bad. What can I do for ground-start lines?
Thank you!
Hall of Fame Super Gold
Re: How to test ground-start analog lines?
With a buttset. A good one can be expensive.
You have to hook up a buttset then place a ground across the two terminals.
Hall of Fame Super Red
Hi Ryan,
Just to add another hint to the good tips from Paolo and Brian
If you terminate this line on a standard "surface mount " jack (rj11)
that has accessable "spade tip" style terminals and then plug an Analog
phone into the jack, you should be able to touch a ground to the 'Ring" side
of the line while off-hook to pull dialtone.
Cheers!
Rob
Five stars for you too Rob.
I always wanted to own a buttset but never did
Turns out the router has FXS cards in it
I'm sending out FXO cards today.
2631
