10-31-2013 06:21 AM - edited 03-16-2019 08:10 PM
I need to compile information relating to the number of calls our operator handles in a given day, but am unsure how to do this. We are on CM V8.0.3.20000-2, using Fidelus console for the operator phone. Our old system ran reports that would give us these details, but I haven't been able to find anything in CM that lets me do this. I have our CDR's saved and could manually go through them, but need to get this info rather quickly, so would rather not have to do that.
Solved! Go to Solution.
10-31-2013 06:43 AM
You should be able to find the report using Cisco Analysis and Reporting (CAR). You can find it under Navigation > Cisco Unified Serviceability > Tools > CDR Analysis and Reporting. The "Traffic Summary based on Extension" report seems to fit your needs.
https://
Hope that helps!
10-31-2013 06:43 AM
https://
Hope that helps!
10-31-2013 07:00 AM
Thanks Raymond, that seems to be exactly what I need! Appreciate it.
