Community Member
How to Transfer Inactive Calls
Dear all,
  I am working now on CUCM 7.0 Migrating Pbx System with new cisco system
the problem i am facing here with receptionist guy is that he need to transfer inactive calls
to the employee
example:
he will call number 6665555 once it ring he need to transfer the call to one of the employees
second problem
i can't call many numbers from the new system most of these numbers are pbx numbers
but this numbers i can reach from any other phones.. what cause this problem
thanx
Mohammed Samir
If you mean transfer a call without it being active or answering it first on the phone that is not possible.
For the calls checks your CSS/partitions/route patterns and whatever you're using to connect the systems.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
I am sure i have no problems with partitions ,Calling search spaces & Patterns
because i can call all numbers outside
only specific numbers i can't reach
most of these numbers are pbx systems
When I debug one of these numbers
Router#debug ccsip calls
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.x.x.x
Source IP Port    (Media): 27366
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 57
Disconnect Cause (SIP)   : 403
Blue
What is the PBX system you have. How is SIP trunk configured. Have you cheked if MTP are required for these calls.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Community Member
actually the problem i face is:
when i am trying to call some numbers outside i can't reach these numbers
these numbers outside is connected to pbx systems
from my side i am not dealing with pbx because its in different network
Mohammed
Blue
So how is your PBX connected to your CUCM. May be the calls requires MTP to get completed. If it is through SIP trunk, Select MTP require in SIP trunk and have MTp resources in its MRG and MRGL.
Ronak Patel
Community Member
There is no connection between cucm and pbx
Community Member
Oh my god !!
the issue always came from the Service Provider
they ask me to use ulaw before
but now they told me to change to alaw and it works fine now
thanx all for help
334
