How to upgrade 7941 to use SIP
lruberintwari
I would like to upgrade 7941 to Sip (attached). I have used tftp32 on my  Windows 7 and i have configured DHCP into my tffp with other required option. I connected my pc and 7941 to P0E switch . I tried to boot my phone and watch Tftp server in order  to have some activity showing the upgrade process bu nothing happen. thanks for advising
Manish Prasad
Level 5
Level 5
Try adding TFTP server ip manually on phone.
Here is the link that will help you.
http://www.cisco.com/c/en/us/support/docs/collaboration-endpoints/unified-ip-phone-7900-series/5455-handset-to-sip.html
Rate all helpful post.
Manish
triumph_w
Hi, I met similar problem when I tried to upgrade my 7941G from SCCP to SIP.
I used to successfully upgrade a 7940G from SCCP to SIP with the tftp32 server. But, with 7941G, it seems the firmware files are much different.
Now my 7941G  only showed a dark screen to me and stopped working. It looks the phone refused to pull the firmware from the server as I can't see any files happened. Maybe the firmware we had is not enough, I guess.
Error message and tftp32 settings
Go HERE.
