Community Member
How to upgrade C1861-SRST-C-F/K9 to support ISDN?
I own a C1861-SRST-C-F/K9 but it has only FXO and FXS ports.
How can I upgrade it to support telephony over ISDN?
I tried to find a compatible card for the HWIC port but there are many that are not supported?!
It would be great if someone can share her/his experience on this topic
Kind regards
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
Community Member
Re: How to upgrade C1861-SRST-C-F/K9 to support ISDN?
Hi Sol,
Q. Does the Cisco 1861(E) support the digital voice/WAN interface cards (VWICs)?
A. No, digital voice interface cards are not supported on the Cisco 1861(E) at first customer shipment (FCS).
Q. Is the T1/E1 HWIC with integrated channel service unit/data service unit (CSU/DSU) (HWIC-1T1/E1) module data-only, or can it support voice capabilities such as fractional PRI?
A.  It is a data-only module.
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/ps8321/prod_qas0900aecd806c4def.html
Kind regards,
Andrew C.
Kind regards, Andrew C.
Hall of Fame Super Red
Hi Sol,
These aren't going to work either
Restrictions for ADSL HWICs
ADSL  HWICs can be inserted only into onboard HWIC-enabled slots on Cisco  routers. Initially, these routers are the Cisco 1800 series (modular),  the Cisco 2800 series, and the Cisco 3800 series integrated services  routers.
The ISDN interfaces on HWIC-ADSL-B/ST and HWIC-ADSLI-B/ST are data only.
ATM adaption layer 2 (AAL2) is not supported.
ADSL  HWICs do not support dual latency. When the ADSL link is intended to  support both voice and data traffic simultaneously, the link should be  configured for either all fast-path data or all interleave data with an  interleave depth of zero to insure that latency is minimized. In  addition, the total supported data rate must be reduced to adjust for  the reduced coding gain, which is usually present with high-latency  traffic.
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/dsl_hwic.html
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Community Member
Hi Sol,
Kind regards,
Andrew C.
Community Member
Hi Andrew,
thank your for your answer.
So there is NO way other than exchanging the complete device?
I really hoped that "at first customer shipment (FCS)" is some time ago
Kind regards
Community Member
Hi Sol,
Judging at the document I found, there is no way to connect it to ISDN PRI/BRI indeed. You can consult with your local reseller to be completely sure, though.
Kind regards,
Andrew C.
Community Member
I found (HWICs Supported in the HWIC Slot):
HWIC-ADSL-B/ST (Dual-port HWIC with ADSL over POTS and ISDN BRI ports (12.4(20)T, 12.4(22)T and later))
HWIC-ADSLI-B/ST (Dual-port HWIC with ADSL over ISDN and ISDN BRI ports.(12.4(20)T, 12.4(22)T and later))
They both offer one ISDN BRI port as "backup".
Has anyone used something like this for a voice connection?
Kind regards
Hi Sol,
Cheers!
Rob
- The Band
Community Member
I am afraid you are right
Thank you all for your effort!
Kind regards
187
