Community Member
how to upgrade CUCM 6.0.1a to 6.1.2
Hey
We are trying to upgrade a MCS 7800 running CUCM 6.0.1 to CUCM 6.1.2. I did some research and found that it can directly upgrade, but the upgrade file is so big it is in two parts. We have tried this command:
cat UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 > UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
But it say "<" invalid anyone else has this problem ?
Green
Dwayne,
Have you downloaded the 2 files to a windows machine ?
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Community Member
ok I got though with this for and one else having trouble combining these files use the windows cmd and follow the commands in the img
VIP Super Bronze
The release notes show a different command:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp553371
COPY /B UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2+UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
Please remember to rate helpful responses and identify helpful or correct answers.
Community Member
ok I left out a step in the cmd but here is all
This is for windows
c:\user\name> cd..
c:\user>cd..
c:\> cd c:\ name of folder
c:\name of folder> COPY /B UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part1of2+UCSInstall_UCOS_6.1.2.1000-13.sgn.iso_part2of2 UCSInstall_UCOS_6.1.2.1000-13.sgn.iso
like jonathan said use that command to combine the both files, which will be in the folder <> that you will create on the C drive
268
