How to upgrade the firmware of Cisco ATA-187 ?
Can someone share on how to upgrade the firmware of ATA-187? I found some documents for detailed procedure in upgrading ATA's firmware...but it is for ATA-186/188.
Thank you,
shawn
1 ACCEPTED SOLUTION
VIP Purple
VIP Purple
Hall of Fame Super Silver
Search this forum for similar issue, assuming you have firmware 3.2.3 or below that is not upgrading to latest firmware as this is a known memory limitation.  You basically need to change the TFTPUrl on the http:///dev page and point it to a local TFTP running lets say on your PC with the modified config file.
HTH,
Chris
hi aman,
thanks for the reply. however, the link you provided  shows how to upgrade ATA-187 using CallManager. I am using CME in this  case. Got any link on how to upgrade using CME?
regards,
shawn
VIP Purple
great aman
will try that one..
2394
