12-13-2013 09:59 AM - edited 03-16-2019 08:51 PM
Hello Guys!!!
Recently, I changed the option telephonenumber attribute in my CUCM and CUP by ipPhone.!! In my CUCM the change was good, but when I changed in my CUP, The Jabber Client doesn´t work with the new change.
CUP: 8.6.4.10000-28
Jabber 9.0.5
CUCM 8.6
Solved! Go to Solution.
12-13-2013 10:31 AM
Did you change the mapping in the jabber-config.xml??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
12-13-2013 10:31 AM
java
12-13-2013 01:45 PM
