How to use ipPhone attribute in Cisco Jabber
Hello Guys!!!
Recently, I changed the option  telephonenumber attribute in my CUCM and CUP by ipPhone.!! In my CUCM the change was good, but when I changed in my CUP, The Jabber Client doesn´t work with the new change.
CUP: 8.6.4.10000-28
Jabber 9.0.5
CUCM 8.6
1 ACCEPTED SOLUTION
Did you change the mapping in the jabber-config.xml??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
java
java
Re: How to use ipPhone attribute in Cisco Jabber
Thanks for the tips.
I didn´t have the file, and I did it a new one. It works fine.!!
Dennis.
  ipPhone
239
