How to use Sip phones externaly ??
We are running UCM7, and would like to be able to use Sip softphones from internet to our Callmanager..
I guess we need a Cisco Sip proxy, or SIP Express Router ..
any ideas ?
Hall of Fame Super Gold
Re: How to use Sip phones externaly ??
The current solution is called "phone proxy" and runs on the ASA.
However, I recommend you use cisco vpn with the ICPC for much better results.
We are using VPN.
But the solution im looking for is for mobile phone ie Iphone.. normal Sip klient.
Iphone on a wifi network.. would save a lot of roaming charges...
regards
Steffen
Run VPN on the iPhone, then run the client you want.
http://www.networkworld.com/community/node/23023
150
