How to use softphone with Cups
I am just wondering how to use the the softphone function with Personal Communicator 8.5. I don't see where I can switch from a deskphone mode to a softphone mode with 8.5. I'm familiar with IP Communicator and that is working fine but I thought Cisco Personal Communicator was suppose to have a softphone mode.
I am running Call Manager 8, Presence 8 and have tried personal communicator 8 and 8.5. Is there a different install that I need to run to have this functionality? I don't mind installing personal communicator and IP communicator but it would nice to have it all in one install.
  • IP Telephony
Hall of Fame Super Silver
You'll need to build a CSF device in CUCM and associate it with the user as per the configuration guide, and you should have an option on CUPC client to toggle between softphone and deksphone control mode.
Did you build the CSF device?
HTH,
Chris
I have not built the CSF device in CUCM. But still don't even see the option to toggle between softphone and deskphone in personal comm. Is the control Mode option added once the CSF device is created?
VIP Super Bronze
The client intentionally hides this UI option unless all of the needed configuration is in place. The deployment guide walks you through the CSF device creation:
http://www.cisco.com/en/US/docs/voice_ip_comm/cups/8_6/english/install_upgrade/deployment/guide/dgclient.html#wp1091492
Please remember to rate helpful responses and identify helpful or
Gold
Hi Edward
Chris has it (+5) and I've somehow managed to +5 you to!
Yes, once you create the CSF device, you will be able to toggle as per the attached screen shot. There is a check box alongide the "Use my Cisco 6921 for audio" button.
You will need to associate the CSF device to the end user like you do with a desk phone.
HTH. Barry
Thanks. Awesome information guys. I think I got this working now.
Thanks again!
278
