Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
How to verify the following in 7960 IP Phone?
Hi All,
How do I verify the following in 7960 IP Phone,
1. IP address of the phone
2. CME software version
3. Extension number
And how to access the GUI prompt of Cisco 7960 IP phone?
Thank you,
Re: How to verify the following in 7960 IP Phone?
you can use show commands:
Commands: show ss7 sm set through shutdown (voice-port)
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_sh4_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1011792
Cisco Unified CME Commands: sast1 trustpoint through show fb-its-log
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_s1ht.html
The whole config guide
Cisco Unified Communications Manager Express System Administrator Guide
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm.html
To access phone GUI just type the IP of the phone in a browser
java
if this helps, please rate
java
www.cisco.com/go/pdi
Bronze
Hi friend.
1. Settings->Network Configuration to check IP, Mask, Gateway, TFTP.
2. You can check only the firmware.
3. If the phone is configured, you can check directory number on the display of the phone.
To web access: http://IPPhone-IP
All the best
David
152
