10-22-2007 10:57 AM - edited 03-15-2019 06:57 AM
Hi all,
I have the following issue:
An external, incoming call is redirected (on a IP-Phone) to 3-party voicemail. The problem is, that there is no redirect-calling nummer (should be the local internal-nr.) in the information to the voicemail.
I need the redirect-nr information for the voicemail.
Here the ephone-dn settings (2999=>voicemail):
ephone-dn 167
number 2407 no-reg primary
label number(2407)
description 0xx/xx.xx.xx
name number 7
call-forward all 2999
call-forward noan 2999 timeout 3
Here the Voice-mail dial-peer:
dial-peer voice 11 voip
description ** VOICEMAIL **
destination-pattern 2999
voice-class h323 1
session target ipv4:192.168.x.x
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
Can I somehow set the redirect-nr (local) under the ephone-dn or do I have to do some changes under the BRI0/0/0?
Can anybody explain me what the "extract_redirect_orig_called_ie: IE type redirecting num none reason..."
debug output means?
Here some debug from the ISDN (Switzerland):
000254: Oct 22 17:01:25.928: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x47
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Facility i = 0x91A1130202008002010F300A0201010A0101A1028100
Protocol Profile = Remote Operations Protocol
0xA1130202008002010F300A0201010A0101A1028100
Component = Invoke component
Invoke Id = 128
Operation = Diversion Leg2
Progress Ind i = 0x8083 - Origination address is non-ISDN
Calling Party Number i = 0x0181, '0819262410'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '320'
000255: Oct 22 17:01:25.928: ISDN BR0/0/1 Q931: extract_redirect_orig_called_ie: IE type redirecting num none reason 15cnt 1 plan -1 type 0 pres 1
000256: Oct 22 17:01:25.940: ISDN BR0/0/1 Q931: TX -> CALL_PROC pd = 8 callref = 0xC7
Channel ID i = 0x8A
Exclusive, B2
000257: Oct 22 17:01:26.152: ISDN BR0/0/1 Q931: TX -> ALERTING pd = 8 callref = 0xC7
000258: Oct 22 17:01:27.228: ISDN BR0/0/1 Q931: TX -> CONNECT pd = 8 callref = 0xC7
Channel ID i = 0x8A
Exclusive, B2
000259: Oct 22 17:01:27.296: ISDN BR0/0/1 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x47
000260: Oct 22 17:01:27.296: %ISDN-6-CONNECT: Interface BRI0/0/1:2 is now connected to 0819262410 N/A
000261: Oct 22 17:01:29.784: ISDN BR0/0/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x47
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
000262: Oct 22 17:01:29.784: %ISDN-6-DISCONNECT: Interface BRI0/0/1:2 disconnected from 0819262410 , call lasted 2 seco
nds
Any hints?
Thanks an regards,
Norbert
10-26-2007 11:10 AM
The error "extract_redirect_orig_called_ie: IE type redirecting num none reason" is usually caused by incorrect isdn switch type config. Following link may help you for ephone-dn settings
10-28-2007 12:49 PM
there may be two separate issues here. First, the message in debug isdn, it is due the telco is placing the call, with a ROP operation and the calling number twice. Not sure if this is related to the below, do all call come in this way that is a bit strange ?
Then if the voicemail is not seeing the redirecting number, can you take "debug cch323 all" to chek what the router is sending>
10-29-2007 03:03 AM
Hi all,
thanks for the reply.
Actually, the ISDN-debug "extract_redirect_orig_called_ie" only appears with an incoming redirected call from a mobile and it's telco related.
My workaround to solve this issue is, I put a translation redirect-called rule on the voice-port. So I got the redirect-information for the voicemail.
Greets,
Norbert
04-15-2008 08:25 AM
Hello Norbert, can you please post your detailed workaround? I have the same issue now with callisto express h323 (voicemail) and cme 4.2. When a external call is redirected to the voicemail then the voicemail is not receiving the redirecting id.
Here is the debug of the voicemail:
2008-04-15 18:05:42 Incoming Call. Called=999 Caller=0313001000 Redir=
2008-04-15 18:05:42 License: 2 Call(s). In use: 1 Call(s).
2008-04-15 18:05:43 Translated Numbers. Called=999 Caller=0313001000 Redir=
Normally behind the "Redir=" there is the redirecting number for the voicemail.
With CME 3.4 this worked with no problems.
Thanks for the help.
Regards Lukas
04-15-2008 09:22 AM
Which exact IOS do you have ?
04-15-2008 10:35 PM
Hello, I've got:
c2801-spservicesk9-mz.124-11.XW6.bin
Regards Lukas
04-16-2008 09:12 AM
Hi Lukas,
It's on a 4.1 CCME (Version 12.4(11)XJ) with
Callisto H323.
The PSTN-connection is configured as special arrangement.
voice translation-rule 40
rule 1 /\(.*\)/ /0\1/
voice translation-rule 35
rule 5 /^0\(..\)/ /20\1/
rule 10 /.*/ /2000/
voice translation-rule 200
rule 1 /.*/ /2000/ => change the ridirect nr.
voice translation-profile extension
translate calling 40
translate called 35
translate redirect-called 200
voice-class h323 1
session target ipv4:192.168.18.11
codec g711ulaw
no vad
This sample is on a 4.2 ccme (Version 12.4(11)XW5) with SIP Callisto .
voice translation-rule 30
rule 15 /^0\(..\)/ /2\1/
voice translation-rule 100
rule 10 // //
translate called 30
translate redirect-called 100
dial-peer voice 10 voip
mailbox-selection last-redirect-num
description Callisto Voice-Mail
destination-pattern 999
session protocol sipv2
dtmf-relay sip-notify
codec g711ulaw
no vad
Maybe there is a better solution, but it worked for me.
Hope this help
Greets,
Norbert
