Community Member
HP Based MCS Server Firmware Update Direct From HP
Greetings, does anyone know if the firmware on the HP varients of the MCS servers can be updated using the Firmware Update CD sourced directly from the HP website or should only the firmware updates made avaliable on Cisco.com be used?
1 REPLY
Silver
Re: HP Based MCS Server Firmware Update Direct From HP
Check the bug:
CSCsl04537: Update HP SAS HDD firmware HP Critical Advisory, c01186030
Field Notice: FN - 63155 - Certain MCS-7835 and MCS-7845 HP Servers May Require a Hard Drive Firmware Upgrade:
http://www.cisco.com/en/US/ts/fn/631/fn63155.html
141
