hp dl320-g2 software upgrade
Hi to all,
i have a hp dl320-g2 software upgrade that i have to use as subscriber.
My publisher is running CCM 4.2 so i have to install this version that requires minimum OS WIN 2000.4.2sr2.
I have win 2000.2.7.
which step have i to perform and which software i need to upgrade from 2000.2.7 to 2000.4.2sr2.
(links and answers will be useful)
Hall of Fame Super Red
Re: hp dl320-g2 software upgrade
Hi Alessandro,
Here are some docs to get you started with this process;
Installing the Operating System on the Cisco Unified Communications Server, Versions 2000.4.3 and 2000.4.3a
http://www.cisco.com/univercd/cc/td/doc/product/voice/iptel_os/install/os200043.htm#wp520256
http://www.cisco.com/univercd/cc/td/doc/product/voice/iptel_os/install/os200043.htm#wp475228
Installation Procedures and Release Notes for the Cisco-provided Operating System
http://www.cisco.com/univercd/cc/td/doc/product/voice/iptel_os/install/index.htm
For installation instructions, refer to the file-specific readme document, Cisco IP Telephony Operating System, SQL Server, Security Updates, and Installing the Operating System on the Cisco IP Telephony Applications Server. To obtain the most recent version of these documents, go to;
http://www.cisco.com/kobayashi/sw-center/sw-voice.shtml.
Installing Cisco CallManager Release 4.2(1)
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_2/install/instcall/cm421ins.htm#wp473584
Hope this helps!
Rob
thanks,very helpful!
143
