HP DL380 G4 installation failure
Hi, I'm trying to install Call Manager on a HP DL380-G4 using OS 2000.4.3a. The hardware that I'm using follows Cisco specifications http://www.cisco.com/en/US/customer/products/hw/voiceapp/ps378/prod_brochure09186a0080107d79.html
except for the "BBWC Enabler for SA6i+".
All the 4 72,8 GB HDD are connected to SCSI 2 "Simplex configuration" but the installation fails during the OS image copy process from the DVD to the disk array (TAC Case K03201733).
It looks as if the setup process isn't able to create the drive array and format the disks.
I've already successfully installed other servers with the same DVD and SCSI controller but only 1 CPU and two disks.
Has anybody encountered the same problem ?
  • IP Telephony
113
