Hunt group and Call forwarding
Hi All,
I am trying to find out if there are 10 phones in a hunt group and one of the phones has set calls to be forwarded to a mobile, will the hunt forward calls to the mobile phone if that phone is hunted next?
Or does the hunt ignore the personal settings of the phone.
Hall of Fame Super Silver
Call forwarding setting on
Call forwarding setting on the DN is ignored when call arrives via hunt group.
Chris
Thanks Chris. Is there a
Thanks Chris. Is there a workaround for the CFA to work in a hunt group?
You can use call forwarding
You can use call forwarding on the hunt pilot itself, or you can you mobile connect (single number reach).
Chris
You can also use SNR
java
if this helps, please rate
www.cisco.com/go/pdi
71
