11-29-2010 01:26 PM - edited 03-16-2019 02:10 AM
-- CUCM 7.1.5
-- MGCP Gateway
I have two separate overhead paging zones, each zone connects to the voice gateway using a separate FXS port.
Zone A is on FXS 0/1/0
Zone B (DN 192) is on FXS 0/1/2
I am trying to create a hunt group so that users can page both zones at the same time.
Here's how I setup the hunt group;
Hunt Pilot = 193
Members = 190 and 192
Distribution Algorithm = Broadcast
190 and 192 are the DNs for their respective FXS ports. When I dial these, a paging adapter picks up and the audio goes over the overhead speakers. These are working fine when dialed individually, but when I call the hunt pilot, only Zone A with DN 190 hears audio.
How can I configure this so that when I dial the hunt pilot (193), audio flows across both FXS ports?
Line Group configuration is below.
Thanks in advance!
11-29-2010 02:18 PM
I haven't tried this myself with FXS but my guess is that this won't work, if you do the same with IP Phones trying to emulate a broadcast by enabling auto-answer the same behavior occurs.
You ring all devices, but only the 1st one to pickup gets the audio stream.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
11-29-2010 02:22 PM
Java,
I believe you are correct, the first device to answer will receive the RTP stream.
Does anyone know of any workarounds to allow paging across two FXS ports simultaneouly?
Thanks!
11-29-2010 08:07 PM
Workaround: Find or write a third-party CTI application that starts an ad-hoc conference call and then adds both FXS ports to the conference.
Solution: Use a third-party paging product such as SingleWire Informacast or SynApps SA-Announce.
11-29-2010 09:05 PM
While SA Announce or Informacast would do the job, either one would be far more costly than simply installing a multi zone paging controller. The difference in costs would probably measured in the thousands of dollars.
Both products work well, but this application is specifically driving overhead speakers already in place and connected to paging contollers (most likely single zone controllers) per the original post.
11-29-2010 02:23 PM
What you are attempting to do will not work.
A hunt groupd will do a broadcast ring, but the first station to answer the call gets the call. The other station does not.
If you want to be able to send a call to multilple paging zones, you need a multi zone paging controller. There is no way to rig CallManager to compensate for not having it.
