Hunt Group CME 8.6 Configuration
Hi!
I just installed a new CME 8.6 with 20 ephones 9621 sccp. I need to create a hunt group ringing 3 seconds and if noan or busy, ring the next one.
I followed these steps but stills fails, what could be the problem?
voice hunt-group 1 parallel
pilot 1000
list 4010, 4011, 4012, 4013
final 4013
timeout 20
I tried to with the ´noan and busy command´ but does not working. When I call to a ephone, rings and after 10 seconds tried to forward the call to the next one, but instead of do that, drop calls.
Waiting for your responds.
Regards!
Hall of Fame Super Gold
You should avoinf parallene hunt-groups as they don't work very well. Used instead sequential ephone-hunt, or shared lines.
The problem was already resolved, the pilot number must to be the same that the one I used in voice traslation-rule to receive incoming calls.
regards.
388
