Community Member
hunt group fails in cme 8.6
I have a hunt group configurated with 6 extension, I place a call from pstn to the firs extension and works fine, but after 3 rings is not forwarding to the next one in the hunt group, this is the hunt group configuration:
ephone-hunt 1 sequential
pilot 5001
list 4014, 4013, 4012, 4011, 4016, 4015
final 4015
preference 1
timeout 15, 15, 15, 15, 15, 15 ephone-hunt 1 sequential
pilot 5001
final 4015
preference 1
And this is the debug isdn Q931:
Jul  9 08:37:01.954: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8  callref = 0x2C
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x81
                Preferred, B1
        Calling Party Number i = 0x0183, '6........´'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, '91.......´'
                Plan:ISDN, Type:National
Jul  9 08:37:01.962: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xAC
        Channel ID i = 0x89
                Exclusive, B1
Jul  9 08:37:01.978: ISDN BR0/0/0 Q931: TX -> ALERTING pd = 8  callref = 0xAC
        Progress Ind i = 0x8188 - In-band info or appropriate now available
Jul  9 08:37:11.966: ISDN BR0/0/1 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x1, Calling num 6........
Jul  9 08:37:11.966: ISDN BR0/0/1 Q931: Sending SETUP  callref = 0x0030 callID = 0x8038 switch = basic-net3 interface = User
Jul  9 08:37:11.966: ISDN BR0/0/1 Q931: TX -> SETUP pd = 8  callref = 0x30
                Standard = CCITT
        Channel ID i = 0x81
                Preferred, B1
        Calling Party Number i = 0x0183, '6........'
        Called Party Number i = 0xA1, '13'  <- dn to be transfered and fails
        Sending Complete
Jul  9 08:37:12.158: ISDN BR0/0/1 Q931: RX <- CALL_PROC pd = 8  callref = 0xB0
        Channel ID i = 0x89
                Exclusive, B1
Jul  9 08:37:12.182: ISDN BR0/0/1 Q931: RX <- DISCONNECT pd = 8  callref = 0xB0
        Cause i = 0x829F - Normal, unspecified
        Progress Ind i = 0x8288 - In-band info or appropriate now available
Jul  9 08:37:12.186: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8  callref = 0xAC
        Cause i = 0x809F - Normal, unspecified
Jul  9 08:37:12.366: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8  callref = 0x2C
        Cause i = 0x82E31E - Information element not implemented  <- What does this mean????
Jul  9 08:37:12.370: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xAC
Jul  9 08:37:12.374: ISDN BR0/0/1 Q931: TX -> RELEASE pd = 8  callref = 0x30
Jul  9 08:37:12.438: ISDN BR0/0/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0xB0
thanks!!
Hall of Fame Super Gold
13 is a DN? ehone-hunt can only be used with intrnal extensions.
Please send compelte configuration as there is some confusion above.
Community Member
Hi again!
Ok, here you are all the configuration:
sh run
Building configuration...
Current configuration : 9779 bytes
! Last configuration change at 09:14:53 UTC Mon Jul 9 2012
! NVRAM config last updated at 08:43:21 UTC Mon Jul 9 2012
version 15.1
hostname Router
boot-start-marker
boot-end-marker
enable secret 4 obRb0FadGuBVjVW5otVGkzARTiq/QoD9hkzBWF025sM
no aaa new-model
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 BRI0/0/0
network-clock-select 2 BRI0/0/1
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.100.1 192.168.100.10
ip dhcp pool VOZ
network 192.168.100.0 255.255.255.0
domain-name VOZ
option 150 ip 192.168.100.2
default-router 192.168.100.2
lease 8
no ip domain lookup
isdn switch-type basic-net3
crypto pki trustpoint TP-self-signed-509137687
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-509137687
revocation-check none
rsakeypair TP-self-signed-509137687
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
registrar server expires max 600 min 60
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice translation-rule 1
rule 1 /91XXXXXXX/ /4014/ <-- Telephone changed
voice translation-profile PSTN1
translate called 1
license udi pid CISCO2901/K9 sn FCZ162494UF
license accept end user agreement
license boot module c2900 technology-package uck9
hw-module pvdm 0/0
username julia privilege 15 secret 4 obRb0FadGuBVjVW5otVGkzARTiq/QoD9hkzBWF025sM
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.100.2 255.255.255.0
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.200.2 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI0/0/0
no ip address
isdn point-to-point-setup
isdn voice-priority always
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn static-tei 0
interface BRI0/0/1
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI0/1/0
no ip address
isdn send-alerting
isdn static-tei 0
interface BRI0/1/1
no ip address
isdn send-alerting
isdn static-tei 0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path CUCME
tftp-server flash:p00307020300.bin
control-plane
voice-port 0/0/0
compand-type a-law
cptone ES
timeouts interdigit 3
voice-port 0/0/1
compand-type a-law
cptone ES
voice-port 0/1/0
compand-type a-law
cptone ES
voice-port 0/1/1
compand-type a-law
cptone ES
mgcp profile default
dial-peer voice 1 pots
translation-profile incoming PSTN2
preference 1
destination-pattern 0T
port 0/0/0
dial-peer voice 2 pots
preference 2
port 0/0/1
dial-peer voice 3 pots
preference 3
port 0/1/0
dial-peer voice 4 pots
preference 4
port 0/1/1
dial-peer voice 100 pots
translation-profile incoming PSTN1
preference 1
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 10 pots
destination-pattern 09........
port 0/0/0
forward-digits 9
dial-peer voice 20 pots
destination-pattern 06........
port 0/0/0
forward-digits 9
dial-peer voice 11 pots
port 0/0/1
forward-digits 9
dial-peer voice 12 pots
port 0/1/0
forward-digits 9
dial-peer voice 13 pots
port 0/1/1
forward-digits 9
dial-peer voice 21 pots
port 0/0/1
forward-digits 9
dial-peer voice 22 pots
port 0/1/0
forward-digits 9
dial-peer voice 23 pots
port 0/1/1
forward-digits 9
dial-peer voice 101 pots
preference 2
destination-pattern .T
direct-inward-dial
port 0/0/1
dial-peer voice 102 pots
preference 3
direct-inward-dial
port 0/1/0
dial-peer voice 103 pots
preference 4
direct-inward-dial
port 0/1/1
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
xml user cisco password julia 15
max-ephones 8
max-dn 50
ip source-address 192.168.100.2 port 2000
max-redirect 20
system message Julia Travel
user-locale ES
network-locale ES
load ata 187
load 6921 sccp.9.1.0.75.r5708
time-zone 28
time-format 24
date-format dd-mm-yy
keepalive 15
max-conferences 8 gain -6
moh music-on-hold.au
web admin customer name julia password julia
transfer-system full-consult
transfer-pattern ....
log password julia
secondary-dialtone 0
xmltest
create cnf-files version-stamp 7960 Jul 04 2012 11:30:02
ephone-dn 10 dual-line
number 4010
name Rafael Candeal
ephone-hunt login
ephone-dn 11 dual-line
number 4011
name Alejandro Mesa
call-forward busy 16
call-forward noan 16 timeout 10
ephone-hunt login
ephone-dn 12 dual-line
number 4012
name Trinidad Manglanos
call-forward busy 11
call-forward noan 11 timeout 10
ephone-hunt login
ephone-dn 13 dual-line
number 4013
name Alicia Mencia
call-forward busy 13
call-forward noan 13 timeout 10
ephone-hunt login
ephone-dn 14 dual-line
number 4014
name Monika Romanova
ephone-hunt login
ephone-dn 15 dual-line
number 4015
name Pedro de la Cerda
ephone-hunt login
ephone-dn 16 dual-line
number 4016
name Agustin Peral
call-forward busy 15
call-forward noan 15 timeout 10
ephone-hunt login
ephone-dn 17 dual-line
number 4017
name Sala de Juntas
ephone-hunt login
ephone 1
mac-address 2C54.2D6A.B0F1
max-calls-per-button 2
busy-trigger-per-button 2
type 6921
button 1:10
ephone 2
mac-address 2C54.2D6A.C3B1
type 6921
button 1:11
ephone 3
mac-address 2C54.2D6A.B0F4
type 6921
button 1:12
ephone 4
mac-address 2C54.2D6A.C385
type 6921
button 1:13
ephone 5
mac-address 2C54.2D6A.B327
type 6921
button 1:14
ephone 6
mac-address 2C54.2D6A.C3AD
type 6921
button 1:15
ephone 7
mac-address 2C54.2D6A.B0E1
type 6921
button 1:16
ephone 8
mac-address 2C54.2D6A.C3A7
type 6921
no dnd feature-ring
button 1:17
pilot 5001
final 4015
preference 1
Thanks !!
Community Member
Is working!
In the voice translation-rule 1, i needed to change to he pilot number, not the first extension in the hunt group.
Changing it, all is working fine!!
regards!
414
