05-07-2014 07:26 AM - edited 03-16-2019 10:42 PM
Currently I setup a phone as pilot number and if no answer, it will forward the call to hunt group, in this hunt group it have 5 IP Phone and I using broadcast method to ring all phone. If all IP Phone in hunt group does not answer the call, it will route to next hunt group and this hunt group will route to Auto Attendant in Unity Connection to prompt message. Below is the flow:-
IP Phone ext 4000 ---(no answer, forward to 4050)----> hunt group 4050 (have 5 ext. 5001, 5002 and so on) -----(hunt group phone no answer, forward to 4051)---> hunt group 4051 (route to Unity connection Auto Attendant)
Now I using a phone to call 4000 and no answer, it able forward to 4050 and ring all phone. After 5 ring and no answer, it not route to my pre-define AA and it go to standard Voice Mail message. If I call direct to 4050, I can saw after phone ring and no answer, it able route to next hunt group and then prompt my define AA message.
Do you have any idea how to solved this issues? My CUCM and Unity Connection version is 9.1.
Thank you.
John
05-07-2014 07:56 AM
OK, so, what's the mailbox/call handler DN you want to reach????
05-07-2014 05:37 PM
Hi Jaime, thanks for reply. It should hit my AA DN is 6000 and it is my own recording message. If I used phone call 4000 and let it forward, it will go to hit voice mail DN 7000. This is not I wanted.
05-07-2014 08:41 PM
Then you should configure a call routing rule to catch calls coming from that HP and send them to that call handler.
05-08-2014 06:03 AM
Will you please have a look at my topic also ?
Sorry for intervening
https://supportforums.cisco.com/discussion/12198921/problem-jabra-pro-920-cisco-7942
05-11-2014 12:58 AM
Can I know how to do the call routing rule? I try to do it but still not work, not sure which area got wrong. Do you have sample?
05-12-2014 01:06 PM
Make the rule to match a called number of 4050 to send to the auto-attendant. Can you send screenshots of the call routing rules you configured and the voicemail pilot configuration?
05-14-2014 07:12 AM
Hi Brian, thanks for help. I manage to solved the issues. After I using the forwarding rule, it work.
John
05-11-2014 11:32 PM
Hi John,
Would be using the first redirected number to match in CUC.
In CUC Admin, goto Advanced->Conversation and check the "Use Last (rather than first) redirecting number for routing incoming call"
Ben
05-12-2014 12:43 AM
Hi Ben,
Thanks for your response. But I had try this method and it still not work. Got other way?
Thank you.
John
