hunt Group - questions - forward hunt no answer to vm
CUCM 6.1 BE
created a LG with extensions 201-205 - these are not the users main extensions. They show on the users second line.
When no1 picks up the call into the HP it should go to VM and all the users in the LG should see the message that is left.
how can I achive this?
Re: hunt Group - questions - forward hunt no answer to vm
Ok...
I think I am getting somewhere.
I was able to get the Hunt to VM
But now getting the vm to show for all of the LG people is my next step.
Create a subscriber with the DN from the hunt pilot, set the DNs from those users as alternate extensions.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I did some more research on here and found something else
add the extensions of the LG to MWI settings of the VM box of the subsciber
so I have a LG of dn's 201-205
HP of 571  with FHNA to dn 206
206 is a ctiRP which fwd's to vm
then
added the extensions of the LG to MWI settings of the VM box of the subsciber(206) - reson why I did this is because the LG dn's are users secondary dn's. They only have VMfor their main dn's.
It techinically works but not sure if it's the best practice.
168
