Hunt Group to Unity
I am strugging with a hunt group that I want to forward to Unity.
1 hunt group will be in a CSS/Partition for business hours.
the other hunt group - with the same pilot will be in the default CSS/Partition.
My second hunt group will forward directly to a Unity System Handler. But when I configure this Hunt Group to call my system handler - it goes to Unity, but not the system handler I chose. It goes to the default Unity menu.
Hunt Pilot - 499
Line Group Members - I have tried Empty, A dummy extension with Forward all to 701.
Forward NoAn = 701
Forward Busy = 701
If I dial 701 - it answers with my Auto Attendant.
If I dial 499 - it goes to Unity - "Hello - Cisco Unity Connection messaging....."
Any help is appreciated and will be rated....
Heath
1 ACCEPTED SOLUTION
Re: Hunt Group to Unity
That's expected. Unity default behavior is to use the original called number to choose the mailbox, i assume there is no mailbox for 499 but there is for 701 right?
You could configure call routing rules for calls that come from the hunt pilot to go to whatever call handler you want.
You can also change the behavior if Unity 5.X and above to use the last redirecting number, but you do not mention what you have.
BTW: CFA is bypassed in line group members for calls that arrive thru the hunt pilot
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
I like the second idea about adjusting Unity. I am actually on Unity Connection 7.0.2. and I cannot find the option you are referring to.
Hall of Fame Super Red
Hi Heath,
This is available in Unity Connection 7.x as well;
Via
Cisco Unity Connection Administration
Advanced (towards the bottom of the page)
Conversation Configuration
Use Last (Rather than First) Redirecting Number for Routing Incoming Call
Hope this helps!
Rob
339
