Hunt List with Single Number Reach Issue
We need to configure a hunt pilot for one of our support teams that will ring out to cell phones. I have discovered that a simple CFwdAll on directory numbers does not work with Line Group Members. So I have started to use Single Number Reach as a solution. Here is my plan...
HP 8956
HL Support Group
LG On-Call Person (25 sec RNA)
5316 On-Call DN SNR Enabled (Team Manages Cell Phone Definition)
LG Support Group (20 sec RNA)
88XX Agent 1 SNR Enables
88XX Agent 2 SNR Enables
88XX Agent 3 SNR Enables
ISSUE
During testing, the first Line Group rings perfectly through to the cell phone and On-Call desk simultaneously, but does not ring the 2nd Line Group. After 45 seconds, the call goes to VM as expected. I just cannot get the 2nd Line Group to Ring.
Thanks for you help!
Chris
Re: Hunt List with Single Number Reach Issue
I dont think SNR is really meant for this type of setup.. Think of SNR as shared lines. You cant setup Hunt Pilots and Hunt Lists as shared lines.
The only way I see this working is that if no agent answered, it would roll to unity and say " leave a message or press to 4 to locate an agent"
Then Unity could transfer that call to a DN that has SNR enabled. SNR would then ring the endpoints. (cell phones, etc)
Do a supervised transfer so Unity pulls it back and repeats the message, etc.
So then how do I create an On-Call number that rings out to several cell phones? Any ideas are welcome.
Hall of Fame Super Red
Hi Chris,
Just to add a note to the great ideas from Tommer (+5 points here TCAT :)
Do you have this setting;
On the Line Group 1 config;
Try next member,then,try next group in Hunt List
Hope this helps!
Rob
454
