11-04-2014 08:39 AM - edited 03-17-2019 12:48 AM
I have a Hunt Pilot (DN 473) set to queue calls. When Max Time in Queue is met, I have it set to route to DN 474 on XX_CSS. When No Members are Logged In or Answer, it have it set to route to DN 475 on XX_CSS. Both of these DN's are set to forward to Call Handlers in Unity.
My issue is, when either of these situations occur, it does not forward to the DN's as noted, it forwards to the DN of the HP, which I have had to set up as a Call Handler(CH) in Unity.
This is alright for the Max Wait Time met option as I just have that Call Handler play a message and loop back in the the HP. But for the No Members Logged In, I wish for it to reach a different Call Handler and play a different message and force the caller to leave a message.
Any thoughts on why this might not be working?
Thanks.
Solved! Go to Solution.
11-04-2014 09:12 AM
Can you test it with the below setting enabled in CUC ?
under System Settings -> Advanced -> Conversations
"Use Last (Rather than First) Redirecting Number for Routing Incoming Call"
Gagarin
11-04-2014 08:53 AM
Are you using Unity Connection as the VM component ? Is it SCCP or SIP integration ?
If SIP, then on the trunk settings you might have to enable "Redirecting Diversion Header Delivery - Outbound"
Check this check box to include the Redirecting Number in the outgoing INVITE message from the Cisco Unified Communications Manager to indicate the original called party number and the redirecting reason of the call when the call is forwarded.
Uncheck the check box to exclude the first Redirecting Number and the redirecting reason from the outgoing INVITE message.
You use Redirecting Number for voice-messaging integration only. If your configured voice-messaging system supports Redirecting Number, you should check the check box.
The default value for Redirecting Number IE Delivery - Outbound specifies check box does not get checked.
Gagarin
11-04-2014 08:57 AM
Unity Connection is the VM component, but we are using SCCP, not SIP.
Thanks, JK
11-04-2014 09:12 AM
Gagarin
11-04-2014 09:21 AM
Oh Snap! That works!
Thanks a lot Gagarin!
JK
10-25-2015 11:54 AM
Gagarin,
I had a similar issue that I finally posted here for assistance with and this discussion popped up. Your answer to Josh fixed my problem as well!!
Thank you so much!
Blaine
PS - Here's the link to my issue in case anyone else has something similar: https://supportforums.cisco.com/discussion/12687921/trying-route-calls-broadcast-hunt-group-then-auto-attendant-call-handler
10-25-2015 10:00 PM
Blaine,
Glad it helped :)
Gagarin
