Hunt Pilot with Call Forward All ?
Main Number rings into Hunt Pilot > Hunt List > Line Group > Phone A, I want to be able to go the Phone A in the Line Group and use press the Call Forward All softkey to send that Hunt Pilot to another extension while I'm at lunch.
Any way to do that in CallManager 7.1(3)?
  • IP Telephony
1 REPLY
Hall of Fame Super Red
Re: Hunt Pilot with Call Forward All ?
Hi Jason,
You have to keep in mind that a call that has routed via the Hunt Pilot will always ignore the CFWD Settings on Hunt Group Member phones. The normal way to control this then is via the Hunt Group Logout of member phones combined with the Hunt Pilot level forward settings. You would need to setup the other extension as a "Line Group" member that Logs-In at lunch hour :)
The following describes how the Call Forward settings on individual Hunt member phones are ignored when presented a call via the Hunt feature. Here is a clip;
Hunting and Call Forwarding
The concept of hunting differs from that of call forwarding. Hunting allows Cisco Unified Communications Manager to extend a call to one or more lists of numbers, where each such list can specify a hunting order that is chosen from a fixed set of algorithms. When a call extends to a hunt party from these lists and the party fails to answer or is busy, hunting resumes with the next hunt party. (The next hunt party varies depending on the current hunt algorithm.) ***Hunting thus ignores the Call Forward No Answer (CFNA), Call Forward Busy (CFB), or Call Forward All (CFA) settings for the attempted party (Line Group member Phones).
Cisco Unified Communications Manager offers the ability to redirect a call when hunting fails (that is, when hunting terminates without any hunt party answering, due either to exhausting the list of hunt numbers or to timing out). If used, this final redirection comprises a Call Forwarding action. Therefore, the Hunt Pilot Configuration window includes Call Forwarding configuration concepts that are similar to those found on the Directory Number Configuration window.
Example of Call Hunting
Although hunting differs from forwarding, hunting often originates as a call that gets forwarded to a hunt-pilot number. The call coverage feature extends hunting to allow final forwarding after hunting either exhausts or times out.
A typical call that invokes hunting can include the following phases:
The call hunts through provisioned hunt groups according to provisioned algorithms for each group. Hunting either succeeds (if a hunt party answers), exhausts (if all hunt parties are attempted, but none answer), or times out (if the time specified in the Maximum Hunt Timer runs out before all parties are attempted, and none of the parties that were attempted answer).
For the purpose of this example, we assume that hunting does not succeed.
If some form of final forwarding is configured, the call forwards to a next destination; otherwise, the call gets released.
Maximum Hunt Timer
The Maximum Hunt Timer field on the Hunt Pilot Configuration window allows the administrator to enter a value (in seconds) to limit the time for hunting through a hunt list. After the specified time lapses, if hunting has not succeeded, the call gets forwarded to a voice-messaging system, a specific dialed number, or some personal treatment (if configured), or the call gets released.
From this good doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmsys/a03rp.html#wp1078922
If the call goes unanswered or all member phones are logged out, then a Forward should be applied at the "Hunt Pilot" Level;
Hunt Forward Settings
Forward Hunt No Answer - When the call that is distributed through the hunt list is not answered in a specific time, this field specifies how to forward the call.
Destination This setting indicates the directory number to which calls are forwarded.
Forward Hunt Busy - When the call that is distributed through the hunt list is busy in a specific time, this field specifies how to forward the call.
Maximum Hunt Timer - Enter a value (in seconds) that specifies the maximum time for hunting.(Used in conjunction with Forward Hunt Busy)
Cheers!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
3341
