Community Member
Hunt Pilot
Easy question (i think) chaps.
I have a hunt pilot configured to with 3 line groups in a broadcast algorithm.
I want to find out how many calls are being filtered/answered by line group 3 - the last line group for the pilot number.
We have users complaining in line group 3 that users in line group 1 and 2 are not answering the calls as they should be.
hope this makes sense..
Ta
Rod
1 ACCEPTED SOLUTION
Re: Hunt Pilot
the only possible way would be to use CDR since there is no specific reporting on this
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: Hunt Pilot
java
java
Community Member
Re: Hunt Pilot
Thanks for the quick response Java, 2 points for clearing things up for me.
Rod
133
