hunt-scheme in CME does not work?
Even I set hunt-scheme as least-used
It work as sequential
Does anyone test it
Here is my config;
trunk group T-TRUNK
hunt-scheme least-used
preemption enable
translation-profile incoming 1
translation-profile outgoing 12
capacity trunk-group update interval 10
capacity carrier update interval 10
dial-peer voice 444 pots
trunkgroup T-TRUNK
destination-pattern 444
voice-port 2/0/10
trunk-group T-TRUNK
voice-port 2/0/11
trunk-group T-TRUNK
voice-port 2/0/12
trunk-group T-TRUNK
Hall of Fame Super Gold
Re: hunt-scheme in CME does not work?
least-used uses a counter of calls per port, effectively equating to sequential.
May be you wanted to use least-idle.
I test all options;
least-idle
least-used
longest-idle
They dont work as I want;
I want to router to choose least used voice-port in time.
What is timeslot?
Is there any documentation?
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_h1.html
If it doesn't work as described, you have to talk to the TAC.
383
