HUNTGROUP RINGTONES
Is it possible to have a different ringtones for a hunt group call in CME 8.x. If somebody rings my Number directly i should get a different ringtone . And if i get a call as a part of a hunt group  then i should get a different ringtones. Is that Possible in CME 8.X . If so How do i do that.
1 REPLY
Re: HUNTGROUP RINGTONES
No, it is not  possible to configure ringtones based on the ANI or call flow.
You would need to configure 2 lines and use one as primary line and the other as member of a hunt-group in order to do this. You just set a different ringtone per line.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
356
