hunting between 3 pri's
How to configure hunting between 3 pri's on voice gateway?
Hi.For incoming calls, it
Hi.
For incoming calls, it depends on your TSP.
For outgoing, you can use different dialpeer with different preference value.
regards
Carlo
Please rate all helpful posts "The more you help the more you learn"
Or RG/RL if using CUCMFYI,
FYI, just saying what you want, but not what you have to work with, just doesn't work if asking for help.
java
if this helps, please rate
www.cisco.com/go/pdi
30
