hunting between lines for two buttons 7940 CME
I configured the same number extension for both buttons on 7940 IP phone CME. I want the 3rd call to placed on second button. I set
the following conf for the two lines.
I followed the recomendation on admin guide but when the 3rd call is placed is sent to voice mail, I expected to be sent to the second button.
I set Hunt Stop Channel off.
ephone-dn  178  dual-line
number 1971
label 1971
  call-forward busy 5001
call-forward noan 5001 timeout 10
no huntstop
ephone-dn  179  dual-line
number 1971
label 1971
preference 1
Is there something wrong or there si something left??
regards
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: hunting between lines for two buttons 7940 CME
[edited - see posts below]
Hi  bevilacqua
I tried octo-line base on you comments and it works fine.
but I would like to know why my other option doesn't work as I expected to.
thanks a lot for your time
regards
Hi.
I just wanted to clarify, if both the lines are busy, the 3rd call will go to vm as per the config  foward busy to vm in the second line. i think it is a normal behaviour. pls correct me if i am wrong.
Esa
You are right, first DN should have no call-forward . I have rated your post.
I will try not to post anymore when barely awake.
Hi Bevilacqua.
You are great man. You are helping lot of people by answering and spending your valuable time. So it is not to point you, Just i wanted to know the correct behaviour.
Keep answering the question and help us to learn.
Esa
hi guys,
As Esa said , Bevilacqua helps a lot of people,  thanks for your time
I cleared the problem after removing  call-forward busy and noan just on first ephone-dn-
Now it works as I expected to.
number 1971
label 1971
no huntstop
number 1971
label 1971
preference 1
I may help people but sometime I fail to see the very same things I did so many times before
Of course the most preferenced DN must not have call-forward busy set.
So I had edited my posts again hopefully for the last time!
222
