07-01-2013 04:34 PM - edited 03-16-2019 06:10 PM
Background - we have a many pilots around the country. I initially had a request that an Oncall Pilot be reachable at a specific DN and the forwarding from this DN would need to be changable by end users. I associated a DN with a CTI Route Point and then CCMUSER GUI was perfect. A pilot could login and change the forwarding to whatever cell phone they wanted implemented no problem. Yahoo. But then they wanted another permutation. They wanted it so that they could have four pilots be reachable in succession. So if Oncall Pilot A does not answer, ring Oncall Pilot B, and if not him Oncall Pilot C. B and C would likewise need to be changable. I suppose I could just create three DNs each associated with a CTI RP and a DN then forward one to the next. I can't use a hunt group because CTI Route Points and Hunt Groups appear not to mix. Might there be a better way to approach this? Thank you.
07-01-2013 05:16 PM
have you tried using hunt pilots with various Line groups in the Hunt List? in stead of CTI Routepoints?
Please remember to rate useful posts, by clicking on the stars below.
07-01-2013 05:19 PM
Configure SNR for them and use their DNs in the line group
07-01-2013 05:24 PM
If I use SNR (aka Mobility right) - would that need to be configured in conjunction with a physical phone?
07-01-2013 05:26 PM
It seems that when I tested hunt lines/groups with physical phones that the forwarding did not work as hoped. Should I be able to have line group member phones all forwarding calls to their respective cell phones when a call hits the pilot number?
07-01-2013 05:54 PM
No, thats WAD, any call forward behavior is ignored if the call comes from a hunt pilot.
07-01-2013 06:02 PM
Call forward All settings on a line, will not be respected when this line is "dialed" through a LG/Hunt Pilot.
mobility is your answer (most likely) I will lab it later on an let you know.
or you can play with it yourself (device-->remote destination profile , and enable mobility on a user level).
07-01-2013 09:10 PM
Thanks much. Would love to know if I can enable mobility without a phone registered. But still interested if it only works with registered phones, they would just be sad and lonely never answered phones. :-)
07-02-2013 08:43 AM
I ran a few tests...
-Can I edit the Remote Destination with the CCM User GUI. YES
-If I shut/unregister my physical phone (7965G) will the SNR/Mobility work to ring my cell? YES
-If I join my phone's line to a hunt group/list/pilot and the 7965G phone is not registered to CUCM will
the call ring through to my cell phone. YES
So I guess the next thing is to see if I can set up the Remote Destinations and associate them with a non-physical phone and still get YES to all of the above tests.
07-02-2013 09:30 AM
Test: I added a phone copying a CIPC phone naming it randomly and associated it with a DN and associated this device with a user. Then I added a Remote Destination Profile and Remote Destination to the End User Configuration.
Result: FAIL
The call is just going to voice mail. Maybe I'm just missing a step. Any advice appreciated.
