Community Member
Hunting in CUCM 6.1.2
I need assistance in the Hunting settings
we are using CUCM 6.1.2 ,the hunting is working good.
But i want to customize the settings
Required
1.When the members of the Line Group dial outside for Internal extension (CUG) calls . It should Only display the Text "XYZ Team"
2.For Incoming calls coming to that Line group. it should display the DN of the calling Party.
Tried:
1.I tried the Internal alerting, caller Id parameters.But it shows the DN(EXTN) in Braces
eg: XYZ(1234)
2.Tried CLI Resticted option in Hunt Pilot getting Only "PRIVATE" for both incoming and Outcoming.
Looking for the solution
Re: Hunting in CUCM 6.1.2
Look at this for the outbound calls
Call Display Restrictions
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmfeat/fshosp.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
As Per document
i have created a Translation Pattern for Hunt Pilot .
In Translation Pattern
1. I tried Calling Name Presentation -Allowed
2.I tried Connected name Presentation
-allowed
While Calling and Connected Line ID are in restricted.
I am able to see the incoming calls calling the Translation Pattern
Calling Party --- Private
Called Party --- DN of calling Party.
It's Good.
When i am making an outbound call from the line group to calling Party through directory,
It shows
Calling Party --Extension
Called Party --XYX (DN)
Need assistance for the Outbound calls.
132
