I am running call manager 8.0.3.20000-2 on a MCS 7825 I4 can any advise on the upgrade path please?
john.shone
Antonio Knox
Level 7
Level 7
The 7825 I4 should be able to run 9.x {via upgrade to 8.6 then 9.x) , if you have adequate memory and drive space, upgrades may be necessary as I'm not certain if hardware specs you're working with. You can check your model on the compatibility matrix here. http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/prod_brochure0900aecd8062a4f9.html Also, check out the release notes for Cucm 9.x (or 8.6 if that's your target release), I'd post the link but I'm typing this on my phone with bad signal. Please rate of helpful.
Hi John,
you need to have at least 4GB of DRAM along with 160GB of HDD.
you can run show memory count and show memory size from CLI.
regds,
aman
