I am unable to take first line with TAPI.
Hi all,
I am installing a web launcher (Thanks to Paolo) that connect via TAPI.
I have several ephones but in one of it, There are have a problem.
TAPI installation don´t recognize Line 1 of the ephone, but only for ephone 1.
The ephone is a 7965 with two 7915-24 modules.
I have another ephone (ephone 2) with the same modules and I don´t have this problem.
Under ephone configuration, if I set type command to 7965 without modules ( type 7965), then, the Line 1 appear into TAPI installation, but, if I set type command to 7965 with modules ( type 7965 addon 1 7915-24 2 7915-24), don't appear.
I have CUCME 8.8
Anybody have any idea?
Regards.
Everyone's tags (4)
171
