Community Member
I can not call outside to PSTN with CME, help PLEASE!!!
I have a cme with 2E1s, one conected to PBX port 0/0/0 the other connected to PSTN port 0/2/0.
I can receive calls but, I can not call outside using de E1 connected to PSTN.
Here is some logs during the tests but I was not able to call outside to PSTN.
THANK VERY MUCH IN ADVANCE
CCME_LM#
*Dec 14 23:51:55.850: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 24133599
*Dec 14 23:51:55.850: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 55789123
*Dec 14 23:51:55.850: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x021A
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0183, '24133599'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '55789123'
*Dec 14 23:51:55.878: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x821A
Cause i = 0x829F - Normal, unspecified
*Dec 14 23:51:55.882: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 9506
*Dec 14 23:51:55.882: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 55789123
*Dec 14 23:51:55.882: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x021B
Standard = CCITT
Calling Party Number i = 0x0180, '9506'
*Dec 14 23:51:55.910: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x821B
CCME_LM#
Hall of Fame Super Gold
Re: I can not call outside to PSTN with CME, help PLEASE!!!
The switch is actually rejecing the call but no cause is given. Have you tried to place the call with national plan, there is more than one way to do that the easier is at interface level i believe.
Community Member
Hello p.bevilacqua
I have not tried it,
could you tell me how to place the call with national plan??
Thank very much
WF
Just configure numbering-type national under the relevant dial-peer.
Let us know how it works.
Community Member
Besides de type national, this is E1 has 6 GDN.
Could you tell me how to configure the CME for an extension to send his DID instead of the GDN.
THANK VERY MUCH
REGARDS
First you configure a dialplan and did. The under PRI dialpeer configure a calling-number voice translation rune. Possibly the local number with area code will work.
Are you able to call out now?
Let us know how it works and rate post if appropriate... thanks.
Community Member
I am not able to call out, even I added type national on dial-peer on pri e1 0/2/0.
The E1 ISDN PRI HAS 6 GDN, EACH WITH A 5 TRUNKS:
GDN 2413-3500 TRUNKS 1 AL 5
2413-3535 TRUNKS 6 AL 10
2413-3565 TRUNKS 11 AL 15
2413-3599 TRUNKS 17 AL 21
2413-3550 TRUNKS 22 AL 26
2413-3499 TRUNKS 27 AL 31
HOW TO CONFIGURE THE CME TO ASIGNED EACH GND TO HIS TRUNKS????
The incoming call GDN 24133500 to an extension 4011 works fine, here it is a capture.
CCME_LM#
*Dec 18 21:07:30.167: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x004B
Sending Complete
Standard = CCITT
Channel ID i = 0xA98394
Exclusive, Channel 20
Calling Party Number i = 0x0083, '54820634'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '24133599'
*Dec 18 21:07:30.179: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x804B
CCME_LM#
*Dec 18 21:07:30.183: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x804B
Progress Ind i = 0x8188 - In-band info or appropriate now available
CCME_LM#
*Dec 18 21:07:36.971: ISDN Se0/2/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x804B
*Dec 18 21:07:37.003: ISDN Se0/2/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x004B
CCME_LM#
*Dec 18 21:07:37.003: %ISDN-6-CONNECT: Interface Serial0/2/0:19 is now connected to 54820634 N/A
CCME_LM#
*Dec 18 21:07:40.211: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/2/0:19, changed state to up
CCME_LM#
*Dec 18 21:07:48.579: %ISDN-6-DISCONNECT: Interface Serial0/2/0:19 disconnected from 54820634 , call lasted 11 seconds
CCME_LM#
*Dec 18 21:07:48.579: ISDN Se0/2/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x804B
Cause i = 0x8090 - Normal call clearing
*Dec 18 21:07:48.631: ISDN Se0/2/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x004B
*Dec 18 21:07:48.631: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x804B
BUT FOR THE CALL OUT, I SENT A GDN 24133499 DOES NOT GET THROUGH HERE IT IS THE CAPTURE.
CCME_LM#
CCME_LM#
CCME_LM#
*Dec 18 22:43:58.223: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 24133499
*Dec 18 22:43:58.223: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 24131600
*Dec 18 22:43:58.223: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x031F
Standard = CCITT
CCME_LM#
Calling Party Number i = 0x0180, '24133499'
Called Party Number i = 0x81, '24131600'
*Dec 18 22:43:58.251: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x831F
THANK VERY MUCH FOR HELPING
WF
If I understand correctly, the GDN would be five pilot numbers assigned to this PRI.
I don't understand the fixed correlation to the circuit number, but I see the switch selecting a channel in range for the GDN.
I do not see how the call is correctly routed to the wanted extension, as it seem that it goes to a data interface from your capture.
Anyway I understand that only these five numbers can be dialed from outside. Then you want make these pilots ring specific extensions, I think again a voice transformation rule should do that.
It does not seem that the 'non-matching' DID script would help you.
I do not know why you cannot dial after trying national and ISDN dial plans. At the minimum the switch should inform about what is going on but doesn't. One hypothesis, could be the channel order selection. Observe the order the switch select the channels for incoming calls. If is descending, change the order used by the router with isdn bchan-number-order ascending.
All failing is time to ask the telco ..
Community Member
THANK VERY FOR YOUR REPLIES.
I talked to the telco staff, they said that I have to give from the CME from any call.
PLAN:ISDN
TYPE:NATIONAL
SEND THE GDN: 24139599.
I have achieved 2 of 3 items the only that I can not make work is TYPE:NATIONAL.
I added the NUMBERING-TYPE NATIONAL on the dial peer.
When I ran the command: "debug isdn q931", I had the following capture:
TYPE NATIONAL ON DIAL-PEER 801
CME_LM#
CCME_LM#
CCME_LM#
*Dec 18 18:17:41.940: %CALL_CONTROL-6-NUMBERING_TYPE_NO_MATCH: The called number numbering type did not matchThe event for the callid 801 is being discarded.
*Dec 18 18:17:41.944: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 4011
*Dec 18 18:17:41.944: ISDN Se0/2/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Called num 54820634
*Dec 18 18:17:41.944: ISDN Se0/2/0:15 Q931: TX -> SETUP pd = 8 callref = 0x02CC
Standard = CCITT
CCME_LM#
Calling Party Number i = 0x0180, '4011'
Called Party Number i = 0x81, '54820634'
*Dec 18 18:17:41.968: ISDN Se0/2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x82CC
CCME_LM#
This is the part of the configuration
dial-peer voice 801 pots
translation-profile incoming pstn-incoming2
destination-pattern #9T
translate-outgoing calling 2
incoming called-number 24133599
clid network-number 24133599
direct-inward-dial
port 0/2/0:15
Something that I dont see normal is on capture:
I can not yet call out.
THANKS.
HELP ME PLEASE..........
W,
isdn map address will let you change both plan and type.
http://cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080444966.html
PI 0x8183 is normal, do not worry about it.
309
