I can not end a call with button "End Call"
Hi Everyone;
I have a bug that is being presented in CUCM 7 and that is when the receptionist you want to end a call with the button "end call" does not end the call and wait for the caller to finalize, this is a setup for receptionist and making the calls or BLF buttons which will call pick up diverted by groups.
If you have any suggestions or someone and something similar happened, would be helpful your answer and opinion.
thanks
Re: I can not end a call with button "End Call"
Hi Paolo.
Please specify Phone model and firmware version.
Are 7915/16 module attached to the phone?
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi carlo;
The phone is a 7965 with firmware version SCCP45.8-5-3SR1-1S, and do not have any module connected, but if you set blf order to make several calls.
Thanks for the help.
Hi Paolo.
Try to create a new softkey template and apply it to a 7965.
If the proble persists, upgrade phon firmware to the latest compatible version.
Carlo
I'd look at a CUCM trace for the end call softkey event to determine if the issue is that the phone is not sending the event, of if it's sending it, and CUCM is the one ignoring it for some reason.
If this was working before, and suddenly stopped working, and no changes have been done, or FW upgrades, I'd try a restart of CUCM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
158
