I can't make outgoing calls on cisco 2811 router with CME/CUE
hi i can;t make outgoing calls with 2811 integrated router. But suprisingly i can recieve incoming calls. I am new to this so i need some expertise over the config i have made.
version 12.4
hostname CiscoVoip2800
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret 5 $1$91sd$zTNqH5x01eIT.QEONDp5k.
no aaa new-model
resource policy
clock timezone Kuala 8
network-clock-participate wic 0
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.90.149.1 10.90.149.31
ip dhcp excluded-address 10.90.149.96 10.90.149.254
ip dhcp pool Voice
network 10.90.149.0 255.255.255.128
option 150 ip 10.90.149.10
default-router 10.90.149.10
isdn switch-type primary-net5
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g726r16
codec preference 2 g726r24
voice translation-rule 1
rule 1 /^651150/ /150/
rule 2 /^6511151/ /151/
voice translation-rule 9
rule 1 /^911$/ /911/
rule 2 /^9\(.*\)/ /\1/
voice translation-profile translate-incoming-did
translate called 1
controller E1 0/0/0
pri-group timeslots 1-8,16
class-map match-all SIP
match protocol sip
class-map match-all Rtp
match protocol rtp
class-map match-all VOIP-Central
match ip dscp af31
class-map match-all VOIP-Rtp
match ip dscp ef
policy-map ETHOUT
class Rtp
policy-map Output-L3-L2
class VOIP-Central
set cos 3
class VOIP-Rtp
set cos 5
interface Loopback0
ip address 10.1.10.2 255.255.255.0
interface FastEthernet0/0
description $ETH-LAN$
no ip address
duplex full
speed auto
no mop enabled
interface FastEthernet0/0.100
encapsulation dot1Q 100
ip address 10.90.149.10 255.255.255.128
service-policy output Output-L3-L2
interface FastEthernet0/0.200
encapsulation dot1Q 200 native
ip address 10.90.149.129 255.255.255.128
interface Service-Engine0/0
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.0
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1
ip address 10.90.119.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
isdn send-alerting
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.90.119.1 permanent
ip route 10.1.10.1 255.255.255.255 Service-Engine0/0
ip http server
no ip http secure-server
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.sbn
tftp-server flash:P00403020214.bin
tftp-server flash:exit
tftp-server flash:cmterm_7920.4.0-02-00.bin
control-plane
voice-port 0/0/0:15
dial-peer cor custom
name local
dial-peer cor list name
dial-peer cor list local
member local
dial-peer voice 1 pots
description Outgoing
destination-pattern 9[0-9]T
port 0/0/0:15
dial-peer voice 2 pots
description Incoming
translation-profile incoming translate-incoming-did
incoming called-number .
direct-inward-dial
port 0/0/0:15
sip-ua
telephony-service
load 7910 P00403020214
load 7960-7940 P00307020200
max-ephones 42
max-dn 144
ip source-address 10.90.149.10 port 2000
calling-number initiator
system message
time-zone 8
date-format dd-mm-yy
create cnf-files version-stamp Jan 01 2002 00:00:00
dialplan-pattern 1 65111... extension-length 4
voicemail 3000
max-conferences 8 gain -6
web admin system name admin password simple
web admin customer name administrator password simple
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
Hall of Fame Super Gold
Re: I can't make outgoing calls on cisco 2811 router with CME/CU
please send output of "debug isdn q931" with "term mon". Also check "show controllers e1" as you may have slips withiut the needed "network-clock-participate" and network-clock-select" commands.
With debug isdn check what digits your are sending out. Also, you may play with B channel selection order:
no ip address
encapsulation hdlc
isdn bchan-number-order ascending
no cdp enable
Thanks.
The thing is that on a correctly working PRI, selection order will not prevent calls from being placed, but inly increase the possibility of glare.
hi thanks for the all the help ... i have resolved the issue but i am currently facing a problem calling to my other site which is overseas no.
attached is the debug
hello,
I think you need to configure Dp properly, for international call you need 00 and then country codes, I don't see that in the debug attached.
976
