I can't open Cisco Unified Communications Manager Express through Browser
Vikrant Ambhore
Hello All,
We have Cisco 1861, I have done Voip deployment on it, i attached my running-configuration & Flash details, can anyone look it, help me or please let me know if  I am wrong anywhere in config because I'm Unable to open Cisco Unified Communications Manager Express throuh Browser..
Please help me
Vikrant
Sh flash
266       2898 Aug 27 2009 05:28:34 +00:00 cpconfig-18xx.cfg
267    2324992 Aug 27 2009 05:28:50 +00:00 cpexpress.tar
268       1038 Aug 27 2009 05:29:00 +00:00 home.shtml
269     115712 Aug 27 2009 05:29:10 +00:00 home.tar
270    1697952 Aug 27 2009 05:29:28 +00:00 securedesktop-ios-3.1.1.45-k9.pkg
271     415956 Aug 27 2009 05:29:40 +00:00 sslclient-win-1.1.4.176.pkg
272       3987 Nov 13 2010 04:44:20 +00:00 admin_user.html
273     650596 Nov 13 2010 04:44:24 +00:00 admin_user.js
274       1029 Nov 13 2010 04:44:24 +00:00 CiscoLogo.gif
275        617 Nov 13 2010 04:44:24 +00:00 CME_GUI_README.TXT
276        953 Nov 13 2010 04:44:24 +00:00 Delete.gif
277      16344 Nov 13 2010 04:44:24 +00:00 dom.js
278        864 Nov 13 2010 04:44:26 +00:00 downarrow.gif
279       6146 Nov 13 2010 04:44:26 +00:00 ephone_admin.html
280       4558 Nov 13 2010 04:44:26 +00:00 logohome.gif
281       3866 Nov 13 2010 04:44:26 +00:00 normal_user.html
282      78428 Nov 13 2010 04:44:28 +00:00 normal_user.js
283       1347 Nov 13 2010 04:44:28 +00:00 Plus.gif
284        843 Nov 13 2010 04:44:28 +00:00 sxiconad.gif
285        174 Nov 13 2010 04:44:28 +00:00 Tab.gif
286       2431 Nov 13 2010 04:44:28 +00:00 telephony_service.html
287        870 Nov 13 2010 04:44:28 +00:00 uparrow.gif
288       9968 Nov 13 2010 04:44:30 +00:00 xml-test.html
289       3412 Nov 13 2010 04:44:30 +00:00 xml.template
290   34148116 Nov 13 2010 03:01:00 +00:00 c1861-spservicesk9-mz.124-20.T4.bin
291   40593384 Nov 16 2010 21:07:16 +00:00 c1861-advipservicesk9-mz.124-24.T1.bi
n
46907392 bytes available (81276928 bytes used)
5 Replies 5
dksingh
Configure
no ip http secure-server
telephony-serv
  time-web
What do u see when u http://cme_ip_source/ccme.html ?
Which browser (version?)
Hello Dilip,
Thanks for your reply, when i tried to open on browser by http://10.1.20.1/voiceview/common/login.do
I'm getting page can not be displayed, & when i tried to ping router i am able to ping  pls look
I'm able to ping  Vlan 1 (192.168.8.1), Vlan 100 (10.10.10.1)
but unable to ping 10.1.20.1 it's Address for Cisco Unified Communications Manager Express
I hope u understand my issue, pls help
Vikrant,
Your problem is reachability! add route to your PC via CMD to the destination and you should be fine, here is an example
route add -p mask
route add 10.1.20.1 -p mask 255.255.255.0
The -p switch When used with the ADD command, makes a route persistent across boots of the system.
Also make sure your http is enabled.
I hope this helps.
Monty
Sr. Cisco Voice Engineer
HI Vikrant,
Not to be rude but I think you are confused....
Your original post was about not being able to get into CME GUI
and I asked you what u see when trying to go to
http://
But now, it seems you are trying to access VoiceView which is a
CUE feature (not CME)
What are u trying to do ? Can u clarify so that we can understand
andadvise?
If u infact needs voiceview asst. you shd check out:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5520/products_tech_note09186a008067cb94.shtml
DK
vikrant0012007@rediffmail.com
Hello Dilip,
Hello Dilip,
I have this
Melbourne1861#sh telephony-service
CONFIG (Version=7.1)
Version 7.1
