07-10-2013 03:52 PM - edited 03-16-2019 06:19 PM
I all,
My customer recently bought IP Phones 8941 but I can´t register this phone yet.
CUCM version : 8.0.3
IP Phone 8941 firmware :
cmterm-8941_8945-sccp.9-3-2-11.cop Active
cmterm-894x-qed.9-2-2-0.cop Active
cmterm-894x-sccp.9-2-2-0.cop
The IP Phone load the firmware, but isn´t registered in the CUCM.
The status message display
[12:32:39, 10/16/2012] ITLSEP20BBC02008F9.tlv updating
[12:32:39, 10/16/2012] ITLSEP20BBC02008F9.tlv (HTTP)
[12:32:40, 10/16/2012] ITLSEP20BBC02008F9.tlv updated successfully
[12:32:40, 10/16/2012] ITL installed
[12:32:40, 10/16/2012] can't download configuration file SEP20BBC02008F9.cnf.xml.sgn from 10.4.12.2
[12:32:40, 10/16/2012] XMLDefault.cnf.xml.sgn (HTTP)
[12:32:44, 10/16/2012] VPN Error: VPN is not Configured.
[12:32:55, 10/16/2012] CTLSEP20BBC02008F9.tlv updating
[12:32:55, 10/16/2012] CTLSEP20BBC02008F9.tlv not found in 10.4.12.3
[12:32:55, 10/16/2012] ITLSEP20BBC02008F9.tlv updating
[12:32:55, 10/16/2012] ITLSEP20BBC02008F9.tlv (HTTP)
[12:32:56, 10/16/2012] ITLSEP20BBC02008F9.tlv updated successfully
[12:32:56, 10/16/2012] ITL installed
[12:32:56, 10/16/2012] can't download configuration file SEP20BBC02008F9.cnf.xml.sgn from 10.4.12.3
Please, I need your help.
Thanks a lot
Guillermo Silva B
07-10-2013 05:27 PM
Are you sure you're pointing to the right TFTP??
The error clearly says it cannot download the config file.
Try removing and adding the phone again.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
07-10-2013 06:00 PM
Hi JAVA,
The tftp is Ok and is obtained by dhcp.
I think that the problem is associated a security, ctl file, trust list etc.
GSB
Sent from Cisco Technical Support Android App
07-10-2013 09:22 PM
Hi Silva,
Can u try uploading the device pack first and upload firmware 9.3(1) first ? This would require server reboot.
cmterm-devicepack8.0.3.24047-1.cop.sgn |
regds,
aman
07-10-2013 09:24 PM
07-10-2013 10:49 PM
try DOwngrading the firmware to 8.x or 7.x series... it will work.
07-11-2013 08:27 AM
Shabeeb,
I only found firmware 9.x.
How obtain firmware 8.X
Guillermo
07-11-2013 12:09 AM
As it was mentioned by Aman you must install device pack before upgrading 8941 FW
"The Cisco IP Phone 8941 and 8945 support a new "secure by default" feature from 9.3(1) onwards, which requires devpack 8.0.3(24049)/8.5.1(14070)/8.6.2(22030) or higher installed on 8.x Cisco Unified Communications Manager before phones are upgraded to Firmware Release 9.3(2)SR1. If the correct devpack is not installed first, the phones cannot successfully register to the Cisco Unified Communications Manager!!! "
http://www.cisco.com/web/software/282074289/103278/cmterm-8941_8945-sccp.9-3-2SR1-2-readme.html
This is needed to support Security by default
07-11-2013 08:23 AM
Vadym, Aman,
I tried with the firmware 9.2.2 and the problem continue, but the status message display
[00:00:09, 01/01/2010] system boot up (SCCP 9-2-2-0)
[12:28:33, 10/16/2012] SEP20bbc0200a7a Get ip from DHCP server : 10.4.12.11
[12:28:35, 10/16/2012] can't download ctl file from 10.4.12.3
[12:28:51, 10/16/2012] can't download ctl file from 10.4.12.3
[12:41:39, 10/20/2011] SEP20bbc0200a7a Get ip from DHCP server : 10.4.12.11
[12:41:40, 10/20/2011] can't download ctl file from 10.4.12.3
[12:41:55, 10/20/2011] can't download ctl file from 10.4.12.3
[12:42:10, 10/20/2011] can't download ctl file from 10.4.12.3
[12:42:25, 10/20/2011] can't download ctl file from 10.4.12.3
[12:42:39, 10/20/2011] can't download ctl file from 10.4.12.3
[12:42:54, 10/20/2011] can't download ctl file from 10.4.12.3
[12:43:09, 10/20/2011] can't download ctl file from 10.4.12.3
[12:43:23, 10/20/2011] can't download ctl file from 10.4.12.3
The device pack, will upgrade the firmware to all phones ? then I prefer test only the 8941 Phones.
Thanks a lot
Guillermo
07-11-2013 09:00 AM
Do have 89XX models other than 8941as well ?
regds,
aman
07-11-2013 11:04 AM
Hi Aman.
No, we don´t have other 89XX models. Only have 8941.
Guillermo
07-11-2013 09:10 PM
Hi Silva,
this means all the 8941 phones won't be working. Try loading Device pack first and then,firmware.
regds,
aman
02-15-2019 04:31 AM
On Device->Device Settings->Device Defaults you may set the specific firmware per phone type
02-15-2019 04:20 AM
Have got this problem too. Just Reset Security settings in Phone menu. Solved problem for me.
