09-19-2013 10:22 PM - edited 03-16-2019 07:28 PM
Dears
I need your support on this issue , i have 7 FXO " lines " I can only use 2 lines on the outgoing in the same time I don't know what is the issue
Router : cisco 2911
c2900-universalk9-mz.SPA.151-4.M2.bin
voice-port 0/0/1
trunk-group Men-Lines
supervisory disconnect dualtone mid-call
supervisory custom-cptone custom1
supervisory dualtone-detect-params 100
timeouts call-disconnect 3
timeouts wait-release 3
connection plar opx immediate 5050
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
caller-id enable
09-20-2013 08:47 PM
Please share the complete configuration as well a capture of debugs:
deb vpm signal
deb voice ccapi inout
Do not forget the "sh version" of the router.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
09-20-2013 10:48 PM
Dear Jorge ,, thank for your response
application
service aa flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 1
param number-of-hunt-grps 1
param menu-timeout 6
param handoff-string aa
param dial-by-extension-option 1
paramspace english language en
param max-time-vm-retry 2
param aa-pilot 8080
param max-extension-length 4
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt _bacd_welcome.au
param call-retry-timer 15
param voice-mail 1004
param max-time-call-retry 600
param service-name queue
service queue flash:app-b-acd-2.1.2.2.tcl
param queue-len 10
param aa-hunt10 5555
param queue-manager-debugs 1
license udi pid CISCO2911/K9 sn FTX1544ANMK
hw-module pvdm 0/0
voice-port 0/0/0
connection plar opx immediate 1039
caller-id enable
voice-port 0/0/1
connection plar opx immediate 8080
caller-id enable
voice-port 0/0/2
caller-id enable
caller-id alerting dsp-pre-allocate
voice-port 0/0/3
connection plar opx immediate 1030
caller-id enable
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
caller-id enable
voice-port 0/1/2
caller-id enable
voice-port 0/1/3
trunk-group Ladies-Lines
connection plar opx immediate 1017
caller-id enable
voice-port 0/2/0
caller-id enable
voice-port 0/2/1
description 014322049
caller-id enable
voice-port 0/2/2
caller-id enable
voice-port 0/2/3
connection plar opx immediate 1033
caller-id enable
mgcp profile default
dial-peer cor custom
name Local_Ladies
name Mobile_Ladies
name National_Ladies
name Intl_Ladies
name 905_Ladies
name Emrg_Ladies
name 800_900_Ladies
name Local_Men
name Mobile_Men
name National_Men
name Intl_Men
name 905_Men
name Emrg_Men
name 800_900_Men
dial-peer cor list call-local-ladies
member Local_Ladies
dial-peer cor list call-mobile-ladies
member Mobile_Ladies
dial-peer cor list call-national-ladies
member National_Ladies
dial-peer cor list call-intl-ladies
member Intl_Ladies
dial-peer cor list call-905-ladies
member 905_Ladies
dial-peer cor list call-emrg-ladies
member Emrg_Ladies
dial-peer cor list call-800-900-ladies
member 800_900_Ladies
dial-peer cor list Ladies-Access
member Local_Ladies
member Intl_Ladies
member 905_Ladies
member Emrg_Ladies
dial-peer cor list call-local-Men
member Local_Men
dial-peer cor list call-mobile-Men
member Mobile_Men
dial-peer cor list call-national-Men
member National_Men
dial-peer cor list call-intl-Men
member Intl_Men
dial-peer cor list call-905-Men
member 905_Men
dial-peer cor list call-emrg-Men
member Emrg_Men
dial-peer cor list call-800-900-Men
member 800_900_Men
dial-peer cor list Men-Access
member Local_Men
member Mobile_Men
member National_Men
member Intl_Men
member 905_Men
member Emrg_Men
member 800_900_Men
dial-peer voice 1 pots
incoming called-number .
dial-peer voice 31 pots
trunkgroup Ladies-Lines
corlist outgoing call-mobile-ladies
description Mobile Calls Ladies
destination-pattern 905........
forward-digits 10
dial-peer voice 32 pots
corlist outgoing call-national-ladies
description National Calls Ladies
destination-pattern 90[2-4,6-7].......
forward-digits 9
dial-peer voice 8081 voip
service aa
incoming called-number 8080
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
gatekeeper
shutdown
telephony-service
max-ephones 50
max-dn 150
ip source-address 192.168.2.1 port 2000
no caller-id name-only
system message TAQAT Center
time-zone 31
date-format dd-mm-yy
max-conferences 8 gain -6
moh music-on-hold.au
web admin system name xxxxx password xxxxx
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 8
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 26-Sep-11 17:37 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
FoodCo uptime is 2 days, 19 hours, 4 minutes
System returned to ROM by reload at 10:41:47 UTC Wed Sep 18 2013
System restarted at 10:43:20 UTC Wed Sep 18 2013
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco CISCO2911/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FTX1544ANMK
3 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
12 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
Sep 21 05:09:20.927: //-1/CE57AF368B7D/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2B5EB658, Call Info(
Calling Number=441212791111,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=32600442075005000(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=0, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13346
Sep 21 05:09:20.927: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 21 05:09:20.927: :cc_get_feature_vsa malloc success
Sep 21 05:09:20.927: cc_get_feature_vsa count is 3
Sep 21 05:09:20.927: :FEATURE_VSA attributes are: feature_name:0,feature_time:847117472,feature_id:13465
Sep 21 05:09:20.927: //13346/CE57AF368B7D/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=441212791111(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=32600442075005000(TON=Unknown, NPI=Unknown))
Sep 21 05:09:20.931: //13346/CE57AF368B7D/CCAPI/cc_process_call_setup_ind:
Event=0x31A5C7F8
Sep 21 05:09:20.931: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 32600442075005000
Sep 21 05:09:20.931: //13346/CE57AF368B7D/CCAPI/ccCallSetContext:
Context=0x2C71F5A8
>>>>CCAPI handed cid 13346 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:20.939: //13346/CE57AF368B7D/CCAPI/ccCallDisconnect:
Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Sep 21 05:09:20.943: //13344/CDFAE85A8B73/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13344,
Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
Sep 21 05:09:20.943: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 21 05:09:20.943: :cc_free_feature_vsa freeing 327DF3D8
Sep 21 05:09:20.943: vsacount in free is 2
Sep 21 05:09:20.947: //-1/CED876078B82/CCAPI/cc_api_display_ie_subfields:
cisco-username=441212791111
----- ccCallInfo IE subfields -----
Try with the demoted called number 33000442075005000
Sep 21 05:09:21.443: //13350/CF2389FA8B91/CCAPI/ccCallSetContext:
Context=0x2C70F070
Sep 21 05:09:21.447: //13350/CF2389FA8B91/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 13350 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:21.447: //13350/CF2389FA8B91/CCAPI/ccCallDisconnect:
Sep 21 05:09:22.375: //-1/CF3BF3338B96/CCAPI/cc_api_display_ie_subfields:
cisco-ani=441212791111
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=33100442075005000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Sep 21 05:09:22.375: //-1/CF3BF3338B96/CCAPI/cc_api_call_setup_ind_common:
Called Number=33100442075005000(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13351
Sep 21 05:09:22.375: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 21 05:09:22.375: :cc_get_feature_vsa malloc success
Sep 21 05:09:22.375: cc_get_feature_vsa count is 4
Sep 21 05:09:22.375: :FEATURE_VSA attributes are: feature_name:0,feature_time:847115904,feature_id:13470
Sep 21 05:09:22.375: //13351/CF3BF3338B96/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=33100442075005000(TON=Unknown, NPI=Unknown))
Sep 21 05:09:22.375: //13351/CF3BF3338B96/CCAPI/cc_process_call_setup_ind:
Event=0x31A5B358
Sep 21 05:09:22.375: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 33100442075005000
Sep 21 05:09:22.375: //13351/CF3BF3338B96/CCAPI/ccCallSetContext:
Context=0x2C710488
>>>>CCAPI handed cid 13351 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:22.383: //13351/CF3BF3338B96/CCAPI/ccCallDisconnect:
Sep 21 05:09:22.387: //13349/CEE065408B8C/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13349,
Sep 21 05:09:22.387: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 21 05:09:22.387: :cc_free_feature_vsa freeing 327DF2F8
Sep 21 05:09:22.387: vsacount in free is 3
Sep 21 05:09:22.391: //13350/CF2389FA8B91/CCAPI/cc_api_call_disconnect_done:
Try with the demoted called number 33500442075005000
Sep 21 05:09:22.963: //13354/D00B777F8BA5/CCAPI/ccCallSetContext:
Context=0x2C71CD78
Sep 21 05:09:22.963: //13354/D00B777F8BA5/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 13354 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:22.963: //13354/D00B777F8BA5/CCAPI/ccCallDisconnect:
Sep 21 05:09:23.935: //-1/D020D5F68BAA/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=33600442075005000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 21 05:09:23.935: //-1/D020D5F68BAA/CCAPI/cc_api_call_setup_ind_common:
Called Number=33600442075005000(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13355
Sep 21 05:09:23.935: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 21 05:09:23.935: :cc_get_feature_vsa malloc success
Sep 21 05:09:23.935: cc_get_feature_vsa count is 4
Sep 21 05:09:23.935: :FEATURE_VSA attributes are: feature_name:0,feature_time:847115232,feature_id:13474
Sep 21 05:09:23.935: //13355/D020D5F68BAA/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=33600442075005000(TON=Unknown, NPI=Unknown))
Sep 21 05:09:23.939: //13355/D020D5F68BAA/CCAPI/cc_process_call_setup_ind:
Event=0x31A5C7F8
Sep 21 05:09:23.939: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 33600442075005000
Sep 21 05:09:23.939: //13355/D020D5F68BAA/CCAPI/ccCallSetContext:
Context=0x2C70DC58
>>>>CCAPI handed cid 13355 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:23.947: //13355/D020D5F68BAA/CCAPI/ccCallDisconnect:
Sep 21 05:09:23.947: //13353/CFC548028BA0/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13353,
Sep 21 05:09:23.947: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 21 05:09:23.947: :cc_free_feature_vsa freeing 327DF058
Sep 21 05:09:23.947: vsacount in free is 3
Sep 21 05:09:23.951: //13351/CF3BF3338B96/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13357,
Sep 21 05:09:24.375: //13357/D0A4AA278BB4/CCAPI/cc_api_call_disconnect_done:
Sep 21 05:09:24.375: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 21 05:09:24.375: :cc_free_feature_vsa freeing 327DF678
Sep 21 05:09:24.375: vsacount in free is 2
Sep 21 05:09:25.419: //-1/D105B6B38BBE/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=34100442075005000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 21 05:09:25.419: //-1/D105B6B38BBE/CCAPI/cc_api_call_setup_ind_common:
Called Number=34100442075005000(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13359
Sep 21 05:09:25.423: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 21 05:09:25.423: :cc_get_feature_vsa malloc success
Sep 21 05:09:25.423: cc_get_feature_vsa count is 3
Sep 21 05:09:25.423: :FEATURE_VSA attributes are: feature_name:0,feature_time:847115904,feature_id:13478
Sep 21 05:09:25.423: //13359/D105B6B38BBE/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=34100442075005000(TON=Unknown, NPI=Unknown))
Sep 21 05:09:25.423: //13359/D105B6B38BBE/CCAPI/cc_process_call_setup_ind:
Event=0x31A5B358
Sep 21 05:09:25.423: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 34100442075005000
Sep 21 05:09:25.423: //13359/D105B6B38BBE/CCAPI/ccCallSetContext:
Context=0x2C71A548
>>>>CCAPI handed cid 13359 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:25.431: //13359/D105B6B38BBE/CCAPI/ccCallDisconnect:
Sep 21 05:09:25.435: //13358/D0AA28C08BB9/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13358,
Sep 21 05:09:25.435: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 21 05:09:25.435: :cc_free_feature_vsa freeing 327DF058
Sep 21 05:09:25.435: vsacount in free is 2
Sep 21 05:09:25.435: //13356/D0A371D78BAF/CCAPI/cc_api_call_disconnect_done:
Try with the demoted called number 34500442075005000
Sep 21 05:09:25.939: //13363/D1D191778BD2/CCAPI/ccCallSetContext:
Context=0x2C70C840
Sep 21 05:09:25.939: //13363/D1D191778BD2/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 13363 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:25.939: //13363/D1D191778BD2/CCAPI/ccCallDisconnect:
Sep 21 05:09:26.907: //-1/D1EA99768BD7/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=34600442075005000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 21 05:09:26.911: //-1/D1EA99768BD7/CCAPI/cc_api_call_setup_ind_common:
Called Number=34600442075005000(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13364
Sep 21 05:09:26.911: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 21 05:09:26.911: :cc_get_feature_vsa malloc success
Sep 21 05:09:26.911: cc_get_feature_vsa count is 4
Sep 21 05:09:26.911: :FEATURE_VSA attributes are: feature_name:0,feature_time:847114336,feature_id:13483
Sep 21 05:09:26.911: //13364/D1EA99768BD7/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=34600442075005000(TON=Unknown, NPI=Unknown))
Sep 21 05:09:26.911: //13364/D1EA99768BD7/CCAPI/cc_process_call_setup_ind:
Event=0x31A5BDA8
Sep 21 05:09:26.911: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 34600442075005000
Sep 21 05:09:26.911: //13364/D1EA99768BD7/CCAPI/ccCallSetContext:
Context=0x2C7118A0
>>>>CCAPI handed cid 13364 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:26.919: //13364/D1EA99768BD7/CCAPI/ccCallDisconnect:
Sep 21 05:09:26.923: //13362/D18F0B828BCD/CCAPI/cc_api_call_disconnect_done:
Try with the demoted called number 35000442075005000
Sep 21 05:09:27.427: //13368/D2B49FC18BEB/CCAPI/ccCallSetContext:
Context=0x2C71E190
Sep 21 05:09:27.427: //13368/D2B49FC18BEB/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 13368 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:27.427: //13368/D2B49FC18BEB/CCAPI/ccCallDisconnect:
Sep 21 05:09:28.399: //-1/D2CF7A338BF0/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=35100442075005000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 21 05:09:28.399: //-1/D2CF7A338BF0/CCAPI/cc_api_call_setup_ind_common:
Called Number=35100442075005000(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13369
Sep 21 05:09:28.399: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 21 05:09:28.399: :cc_get_feature_vsa malloc success
Sep 21 05:09:28.399: cc_get_feature_vsa count is 3
Sep 21 05:09:28.399: :FEATURE_VSA attributes are: feature_name:0,feature_time:847117472,feature_id:13488
Sep 21 05:09:28.399: //13369/D2CF7A338BF0/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=35100442075005000(TON=Unknown, NPI=Unknown))
Sep 21 05:09:28.399: //13369/D2CF7A338BF0/CCAPI/cc_process_call_setup_ind:
Event=0x31A5C7F8
Sep 21 05:09:28.399: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 35100442075005000
Sep 21 05:09:28.399: //13369/D2CF7A338BF0/CCAPI/ccCallSetContext:
Context=0x2C70F070
>>>>CCAPI handed cid 13369 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:28.407: //13369/D2CF7A338BF0/CCAPI/ccCallDisconnect:
Sep 21 05:09:28.411: //13367/D27488688BE6/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13367,
Sep 21 05:09:28.411: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 21 05:09:28.411: :cc_free_feature_vsa freeing 327DF3D8
Sep 21 05:09:28.411: vsacount in free is 2
Sep 21 05:09:28.411: //13368/D2B49FC18BEB/CCAPI/cc_api_call_disconnect_done:
Try with the demoted called number 35500442075005000
Sep 21 05:09:28.959: //13373/D39DC62F8C04/CCAPI/ccCallSetContext:
Context=0x2C710488
Sep 21 05:09:28.959: //13373/D39DC62F8C04/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 13373 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:28.959: //13373/D39DC62F8C04/CCAPI/ccCallDisconnect:
Sep 21 05:09:29.927: //-1/D3B45CF68C09/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=35600442075005000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 21 05:09:29.927: //-1/D3B45CF68C09/CCAPI/cc_api_call_setup_ind_common:
Called Number=35600442075005000(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13374
Sep 21 05:09:29.927: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 21 05:09:29.927: :cc_get_feature_vsa malloc success
Sep 21 05:09:29.927: cc_get_feature_vsa count is 3
Sep 21 05:09:29.927: :FEATURE_VSA attributes are: feature_name:0,feature_time:847115232,feature_id:13493
Sep 21 05:09:29.927: //13374/D3B45CF68C09/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=35600442075005000(TON=Unknown, NPI=Unknown))
Sep 21 05:09:29.931: //13374/D3B45CF68C09/CCAPI/cc_process_call_setup_ind:
Event=0x31A5B358
Sep 21 05:09:29.931: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 35600442075005000
Sep 21 05:09:29.931: //13374/D3B45CF68C09/CCAPI/ccCallSetContext:
Context=0x2C71CD78
>>>>CCAPI handed cid 13374 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:29.939: //13374/D3B45CF68C09/CCAPI/ccCallDisconnect:
Sep 21 05:09:29.943: //13372/D358CF028BFF/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13372,
Sep 21 05:09:29.943: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 21 05:09:29.943: :cc_free_feature_vsa freeing 327DF2F8
Sep 21 05:09:29.943: vsacount in free is 2
Sep 21 05:09:29.943: //13373/D39DC62F8C04/CCAPI/cc_api_call_disconnect_done:
Try with the demoted called number 36000442075005000
Sep 21 05:09:30.375: //13378/D47674098C1D/CCAPI/ccCallSetContext:
Context=0x2C7154E8
Sep 21 05:09:30.375: //13378/D47674098C1D/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 13378 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:09:30.375: //13378/D47674098C1D/CCAPI/ccCallDisconnect:
Sep 21 05:09:31.415: //-1/D4993DB38C22/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=36100442075005000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Sep 21 05:11:53.567: //-1/2991905694A6/CCAPI/cc_api_call_setup_ind_common:
Called Number=83600442075005000(TON=Unknown, NPI=Unknown),
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=13815
Sep 21 05:11:53.567: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Sep 21 05:11:53.567: :cc_get_feature_vsa malloc success
Sep 21 05:11:53.567: cc_get_feature_vsa count is 4
Sep 21 05:11:53.567: :FEATURE_VSA attributes are: feature_name:0,feature_time:847115008,feature_id:13934
Sep 21 05:11:53.567: //13815/2991905694A6/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Called Number=83600442075005000(TON=Unknown, NPI=Unknown))
Sep 21 05:11:53.567: //13815/2991905694A6/CCAPI/cc_process_call_setup_ind:
Event=0x31A5B358
Sep 21 05:11:53.571: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 83600442075005000
Sep 21 05:11:53.571: //13815/2991905694A6/CCAPI/ccCallSetContext:
Context=0x2C717D18
Sep 21 05:11:53.571: //13815/2991905694A6/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 13815 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:11:53.571: //13815/2991905694A6/CCAPI/ccCallDisconnect:
Sep 21 05:11:53.575: //13812/29083B879
Al_Elm_Riyadh#au497/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13812,
Sep 21 05:11:53.575: //13812/29083B879497/CCAPI/cc_api_call_disconnect_done:
Sep 21 05:11:53.575: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Sep 21 05:11:53.575: :cc_free_feature_vsa freeing 327DF058
Sep 21 05:11:53.575: vsacount in free is 3
Sep 21 05:11:53.575: //13813/2969E236949C/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x2B5EB658, Tag=0x0, Call Id=13813,
Sep 21 05:11:53.575: :cc_free_feature_vsa freeing 327DFAD8
Sep 21 05:11:53.575: vsacount in free is 2
Sep 21 05:11:53.579: //-1/29D241D394AB/CCAPI/cc_api_display_ie_subfields:
Try with the demoted called number 83700442075005000
Sep 21 05:11:53.583: //13816/29D241D394AB/CCAPI/ccCallSetContext:
Context=0x2C7077E0
Sep 21 05:11:53.583: //13816/29D241D394AB/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 13816 with tag 0 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Sep 21 05:11:53.583: //13816/29D241D394AB/CCAPI/ccCallDisconnect:
Sep 21 05:11:54.551: //-1/29ED1C4594B0/CCAPI/cc_api_display_ie_subfields:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=83800442075005000
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
09-21-2013 04:04 AM
Hi Mohamed,
You are using trunk group "trunk-group Ladies-Lines" in only one port
and in both the configured dial-peers
Plz modify one of the dial-peers to be with "trunk-group Men-Lines" so you can use the fxo ports assigned to trunk group "trunk-group Men-Lines"
Or modify some of the FXO ports to be assigned to "trunk-group Ladies-Lines"
Haitham
09-22-2013 04:39 AM
also it's not working
when I tried to use the 3th line I recevied busy tone
I can use these port only 0/0/0 , 0/0/1
01-10-2014 01:09 AM
Hello
http://voiceonbits.com/2010/08/19/ios-15-1-toll-fraud-feature/
just go through above link..
it will help u
thanks
Shrikant
