Community Member
I cannot hear voicemail and AA audio prompt from PSTN calls
I am currently experiencing issues audio issues...
When I dial the auto attendant and voicemail trigger from internal desk phone, everthing works well, i can hear all the prompts.
But if i can the number which is a DID from PSTN, on the Voice gateway, it shows thath the call is connected but i dont hear a thing.
Am guessing a codec issue but nothing has been changed on the Voice gateway.
Snippet of the Config
isdn switch-type primary-net5
voice class h323 1
  h225 timeout setup 30
  telephony-service ccm-compatible
voice class h323 40
--More--                           !
voice-card 0
dspfarm
dsp services dspfarm
application
--More--                           crypto pki trustpoint TP-self-signed-805428843
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-805428843
revocation-check none
rsakeypair TP-self-signed-805428843
archive
log config
  hidekeys
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
framing NO-CRC4
ip tcp synwait-time 10
translation-rule 2
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.10.10.1 255.255.255.248
duplex full
speed 100
interface FastEthernet0/0.707
description ******** CONNECTION TO VOICE DEVICES ********
encapsulation dot1Q 707
ip address 10.31.3.250 255.255.255.128
--More--                           interface FastEthernet0/1
ip address 10.31.2.10 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:15
description ------
no ip address
encapsulation hdlc
no cdp enable
interface Vlan1
no ip address
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.31.3.129
ip route 10.1.2.77 255.255.255.255 10.31.3.132
ip route 10.1.14.0 255.255.255.0 10.31.3.129
ip route 10.1.60.23 255.255.255.255 10.31.3.129
ip route 10.2.11.11 255.255.255.255 10.31.3.132
ip route 10.5.0.0 255.255.0.0 10.31.3.129
ip route 10.20.20.4 255.255.255.252 10.31.3.132
ip route 10.31.0.0 255.255.255.0 10.31.3.132
ip route 10.31.5.0 255.255.255.0 10.31.3.132
ip route 10.31.6.253 255.255.255.255 10.31.3.132
ip route 10.31.7.0 255.255.255.0 10.31.3.132
ip route 10.31.8.0 255.255.255.0 10.31.3.132
ip route 10.31.9.0 255.255.255.0 10.31.3.132
--More--                           ip route 10.31.16.0 255.255.255.0 10.31.2.9
ip route 10.31.23.0 255.255.255.224 FastEthernet0/0.707 10.31.3.129
ip route 10.31.24.0 255.255.255.0 FastEthernet0/0.707 10.31.3.129
ip route 10.31.25.0 255.255.255.0 FastEthernet0/0.707 10.31.3.129
ip route 10.31.26.0 255.255.255.0 FastEthernet0/0.707 10.31.3.129
ip route 10.31.27.0 255.255.255.0 10.31.3.129
ip route 10.31.27.240 255.255.255.248 10.31.3.129
ip route 10.234.100.0 255.255.255.0 10.31.3.132
ip route 10.234.101.0 255.255.255.0 10.31.3.132
ip route 20.20.20.0 255.255.255.0 10.31.3.132
ip route 172.28.1.0 255.255.255.0 10.31.3.129
ip route 192.168.3.0 255.255.255.240 10.31.3.129
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:gui
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 0/0/0:15
voice-port 0/0/1:15
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
--More--                           !
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
sccp local FastEthernet0/0.707
sccp ccm 10.31.0.20 identifier 2 priority 2 version 7.0
sccp ccm 10.31.0.21 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0.707
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 14 register LAG_xcoder
associate profile 5 register DD_MTP
associate profile 4 register DD_CFB
associate profile 40 register hd-confb
registration retries 15
registration timeout 30
switchback method graceful
dspfarm profile 14 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 3
associate application SCCP
dspfarm profile 4 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
--More--                           dspfarm profile 5 mtp
codec g711ulaw
codec pass-through
rsvp
maximum sessions software 6
1 REPLY
Community Member
Hi Segun,
Is CUE JTAPI integrated with CUCM  or SIP integrated with CME?
If on CUCM, please check region configurations between the incoming gateway and the CUE CTI ports. Since CUE accepts only g711 calls, if region is g729 between gateway and CTI port we need to ensure that there is a transcoder on the CTI port mainly, or convert the regions to g711.
Avinash
Regards, Avinash
263
