11-29-2010 06:24 AM - edited 03-16-2019 02:09 AM
I have a CE500 PC-24 POE switch. I am configuring an IP phone on a IPPhone+Desktop smart port. The phone is not a cisco phone. Does this switch port configuration require a cisco phone? If so, Is there a different config which I can apply to the port which will enable the port to trust COS/DSCP values taqgged by the phone? I need to connect PC's to the phones.
11-29-2010 08:53 AM
It the phones is not cisco, it doesn't really matter. Alos, oyu shoud not worry about dcp/cos, it will not make any difference if thye are set or not.
11-29-2010 09:30 AM
The phones will be tagging dscp 46. Will the switch reset the
value or will it trust the value?
11-29-2010 11:59 AM
It will not mess with it.
Even if it would, you would never have a problem anyway.
Please remember to rate useful posts clicking on the stars below.
11-29-2010 12:05 PM
Allow me rephrase the question.
Will the switch Trust the DSCP tag from the
non-cisco phone with this configuration (IP
Phone + Desktop)?
11-29-2010 12:08 PM
Please read my posts above because I have answered your question twice already.
11-29-2010 12:49 PM
Your answer is not
clear. What does "will not mess with it" mean? Does that mean the value will not be reset or does it mean I should not change anything?
