I have question CME 8.0 upgrade to CME 9.1
Pakorn Homhual
Hi All,
I want to upgrade CME 8.0 to CME 9.1 for use CP 3905.
I have question CME 8.0 upgrade to CME 9.1. I can't  add dn phone type 3905.
Cisco Unified CME 9.1 Supported Firmware
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme91spc.html
Cisco Unified CME and Cisco IOS Software Version Compatibility Matrix
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Step upgrade test.
1. I upgrade IOS to 15.2(4)M
sh ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 13:06 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
System returned to ROM by reload at 17:30:49 ict Mon Sep 2 2013
System image file is "flash:c2900-universalk9-mz.SPA.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco CISCO2911/K9 (revision 1.0) with 471040K/53248K bytes of memory.
Processor board ID FHK1449F18H
4 Gigabit Ethernet interfaces
1 ATM interface
2 terminal lines
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
   Cisco Unity Express 8.5.1 in slot/sub-slot 0/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FHK1449F18H
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
2. sh telephony-service
CONFIG (Version=9.1)
Version 9.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.0.3.1 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
no auto-reg-ephone
load 6921 SCCP69xx.9-2-1-0
load 8941 SCCP894x.9-1-2-SR-1
max-ephones 48
max-dn 48
max-conferences 8 gain -6
dspfarm units 0
dspfarm transcode sessions 0
conference software
privacy
no privacy-on-hold
hunt-group report delay 1 hours
hunt-group logout DND
max-redirect 10
voicemail 7777
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US   (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US    (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 12
date-format mm-dd-yy
timezone 41 SE Asia Standard Time
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
keepalive 30 auxiliary 30
timeout interdigit 10
timeout busy 10
timeout ringing 30
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
web admin system name netbright  secret 5 $1$DfTG$Zy1UCClcZMYYgVSjS19Hu.
web admin customer name boyheha  password cisco
edit DN through Web:  enabled.
edit TIME through web:  enabled.
background save interval 10 minutes
Log (table parameters):
     max-size: 150
     retain-timer: 15
create cnf-files version-stamp 7960 Sep 02 2013 10:52:43
transfer-system full-consult
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
3. sh flash
sh flash
-#- --length-- -----date/time------ path
2         2903 Nov 30 2010 21:35:32 +07:00 cpconfig-29xx.cfg
3       677820 Dec 29 2011 16:39:38 +07:00 admin_user.js
4         1038 Nov 30 2010 21:35:50 +07:00 home.shtml
5       115712 Nov 30 2010 21:35:58 +07:00 home.tar
6      1697952 Nov 30 2010 21:36:10 +07:00 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Nov 30 2010 21:36:22 +07:00 sslclient-win-1.1.4.176.pkg
8     99077424 Sep 2 2013 17:30:04 +07:00 c2900-universalk9-mz.SPA.152-4.M4.bin
9         4118 Dec 29 2011 16:39:38 +07:00 admin_user.html
10           0 Dec 29 2011 09:32:04 +07:00 flash
11        4118 Dec 29 2011 16:30:42 +07:00 flash/admin_user.html
12      677820 Dec 29 2011 16:30:44 +07:00 flash/admin_user.js
13        1029 Dec 29 2011 16:30:44 +07:00 flash/CiscoLogo.gif
14        1019 Dec 29 2011 16:30:46 +07:00 flash/CME_GUI_README.TXT
15         953 Dec 29 2011 16:30:46 +07:00 flash/Delete.gif
16       16344 Dec 29 2011 16:30:46 +07:00 flash/dom.js
17         864 Dec 29 2011 16:30:46 +07:00 flash/downarrow.gif
18        6315 Dec 29 2011 16:30:46 +07:00 flash/ephone_admin.html
19        4558 Dec 29 2011 16:30:46 +07:00 flash/logohome.gif
20        3978 Dec 29 2011 16:30:48 +07:00 flash/normal_user.html
21       78428 Dec 29 2011 16:30:48 +07:00 flash/normal_user.js
22        1347 Dec 29 2011 16:30:48 +07:00 flash/Plus.gif
23         843 Dec 29 2011 16:30:48 +07:00 flash/sxiconad.gif
24         174 Dec 29 2011 16:30:48 +07:00 flash/Tab.gif
25        2496 Dec 29 2011 16:30:50 +07:00 flash/telephony_service.html
26         870 Dec 29 2011 16:30:50 +07:00 flash/uparrow.gif
27       10230 Dec 29 2011 16:30:50 +07:00 flash/xml-test.html
28        3412 Dec 29 2011 16:30:50 +07:00 flash/xml.template
29     2942935 Dec 29 2011 16:07:42 +07:00 flash/apps11.8-5-3TH1-6.sbn
30      503269 Dec 29 2011 16:07:44 +07:00 flash/cnu11.8-5-3TH1-6.sbn
31     2104751 Dec 29 2011 16:07:48 +07:00 flash/cvm11sccp.8-5-3TH1-6.sbn
32      340615 Dec 29 2011 16:07:50 +07:00 flash/dsp11.8-5-3TH1-6.sbn
33     1616686 Dec 29 2011 16:07:52 +07:00 flash/jar11sccp.8-5-3TH1-6.sbn
34         670 Dec 29 2011 16:07:52 +07:00 flash/SCCP11.8-5-3S.loads
35         674 Dec 29 2011 16:07:54 +07:00 flash/term06.default.loads
36         674 Dec 29 2011 16:07:54 +07:00 flash/term11.default.loads
37        1916 Dec 29 2011 16:07:54 +07:00 flash/MISCH-1.3.3.SBN
38         900 Dec 29 2011 16:07:54 +07:00 flash/CP7921G-1.3.3.LOADS
39         900 Dec 29 2011 16:07:56 +07:00 flash/CP7925G-1.3.3.LOADS
40         674 Dec 29 2011 16:07:56 +07:00 flash/term42.default.loads
41         674 Dec 29 2011 16:07:56 +07:00 flash/term62.default.loads
42         670 Dec 29 2011 16:07:56 +07:00 flash/SCCP42.8-5-3S.loads
43         655 Dec 29 2011 16:07:56 +07:00 flash/term31.default.loads
44         654 Dec 29 2011 16:07:58 +07:00 flash/term41.default.loads
45         654 Dec 29 2011 16:07:58 +07:00 flash/term45.default.loads
46         654 Dec 29 2011 16:07:58 +07:00 flash/term61.default.loads
47         654 Dec 29 2011 16:07:58 +07:00 flash/term65.default.loads
48         654 Dec 29 2011 16:07:58 +07:00 flash/term70.default.loads
49         654 Dec 29 2011 16:08:00 +07:00 flash/term71.default.loads
50         654 Dec 29 2011 16:08:00 +07:00 flash/term75.default.loads
51         651 Dec 29 2011 16:08:00 +07:00 flash/SCCP31.8-5-3S.loads
52         650 Dec 29 2011 16:08:00 +07:00 flash/SCCP41.8-5-3S.loads
53         650 Dec 29 2011 16:08:02 +07:00 flash/SCCP45.8-5-3S.loads
54         650 Dec 29 2011 16:08:02 +07:00 flash/SCCP70.8-5-3S.loads
55         650 Dec 29 2011 16:08:02 +07:00 flash/SCCP75.8-5-3S.loads
56          61 Dec 29 2011 16:08:02 +07:00 flash/SCCP69xx.8-5-3-0.loads
57           0 Dec 29 2011 09:33:02 +07:00 flash/Desktops
58           0 Dec 29 2011 09:33:04 +07:00 flash/Desktops/320x212x12
59      131470 Dec 29 2011 16:08:04 +07:00 flash/Desktops/320x212x12/CampusNight.png
60       80565 Dec 29 2011 16:08:04 +07:00 flash/Desktops/320x212x12/CiscoFountain.png
61        8156 Dec 29 2011 16:08:04 +07:00 flash/Desktops/320x212x12/CiscoLogo.png
62      138278 Dec 29 2011 16:08:04 +07:00 flash/Desktops/320x212x12/FOUNTAIN.PNG
63         740 Dec 29 2011 16:08:06 +07:00 flash/Desktops/320x212x12/LIST.XML
64      109076 Dec 29 2011 16:08:06 +07:00 flash/Desktops/320x212x12/MorroRock.png
65      108087 Dec 29 2011 16:08:06 +07:00 flash/Desktops/320x212x12/NantucketFlowers.png
66       10820 Dec 29 2011 16:08:06 +07:00 flash/Desktops/320x212x12/TN-CampusNight.png
67        9657 Dec 29 2011 16:08:08 +07:00 flash/Desktops/320x212x12/TN-CiscoFountain.png
68        2089 Dec 29 2011 16:08:08 +07:00 flash/Desktops/320x212x12/TN-CiscoLogo.png
69        7953 Dec 29 2011 16:08:08 +07:00 flash/Desktops/320x212x12/TN-Fountain.png
70        7274 Dec 29 2011 16:08:08 +07:00 flash/Desktops/320x212x12/TN-MorroRock.png
71        9933 Dec 29 2011 16:08:10 +07:00 flash/Desktops/320x212x12/TN-NantucketFlowers.png
72           0 Dec 29 2011 09:33:10 +07:00 flash/Desktops/320x212x16
73         740 Dec 29 2011 16:08:10 +07:00 flash/Desktops/320x212x16/LIST.XML
74           0 Dec 29 2011 09:33:10 +07:00 flash/Desktops/320x216x16
75         740 Dec 29 2011 16:08:10 +07:00 flash/Desktops/320x216x16/LIST.XML
76           0 Dec 29 2011 09:33:10 +07:00 flash/Ringtones
77        8224 Dec 29 2011 16:08:10 +07:00 flash/Ringtones/Analog1.raw
78        8307 Dec 29 2011 16:08:10 +07:00 flash/Ringtones/Analog2.raw
79        5280 Dec 29 2011 16:08:12 +07:00 flash/Ringtones/AreYouThere.raw
80        5040 Dec 29 2011 16:08:12 +07:00 flash/Ringtones/AreYouThereF.raw
81        8206 Dec 29 2011 16:08:12 +07:00 flash/Ringtones/Bass.raw
82       12240 Dec 29 2011 16:08:12 +07:00 flash/Ringtones/CallBack.raw
83       16066 Dec 29 2011 16:08:14 +07:00 flash/Ringtones/Chime.raw
84        8160 Dec 29 2011 16:08:14 +07:00 flash/Ringtones/Classic1.raw
85       16080 Dec 29 2011 16:08:14 +07:00 flash/Ringtones/Classic2.raw
86       10800 Dec 29 2011 16:08:14 +07:00 flash/Ringtones/ClockShop.raw
87        2823 Dec 29 2011 16:08:14 +07:00 flash/Ringtones/DistinctiveRingList.xml
88        9665 Dec 29 2011 16:08:16 +07:00 flash/Ringtones/Drums1.raw
89       13610 Dec 29 2011 16:08:16 +07:00 flash/Ringtones/Drums2.raw
90       15928 Dec 29 2011 16:08:16 +07:00 flash/Ringtones/FilmScore.raw
91       16244 Dec 29 2011 16:08:16 +07:00 flash/Ringtones/HarpSynth.raw
92        8245 Dec 29 2011 16:08:18 +07:00 flash/Ringtones/Jamaica.raw
93       16127 Dec 29 2011 16:08:18 +07:00 flash/Ringtones/KotoEffect.raw
94       12776 Dec 29 2011 16:08:18 +07:00 flash/Ringtones/MusicBox.raw
95        8223 Dec 29 2011 16:08:18 +07:00 flash/Ringtones/Piano1.raw
96       15422 Dec 29 2011 16:08:18 +07:00 flash/Ringtones/Piano2.raw
97        9360 Dec 29 2011 16:08:20 +07:00 flash/Ringtones/Pop.raw
98        7200 Dec 29 2011 16:08:20 +07:00 flash/Ringtones/Pulse1.raw
99        4000 Dec 29 2011 16:08:20 +07:00 flash/Ringtones/Ring1.raw
100       4000 Dec 29 2011 16:08:20 +07:00 flash/Ringtones/Ring2.raw
101       4000 Dec 29 2011 16:08:22 +07:00 flash/Ringtones/Ring3.raw
102       4000 Dec 29 2011 16:08:22 +07:00 flash/Ringtones/Ring4.raw
103       4000 Dec 29 2011 16:08:22 +07:00 flash/Ringtones/Ring5.raw
104       4000 Dec 29 2011 16:08:22 +07:00 flash/Ringtones/Ring6.raw
105       4088 Dec 29 2011 16:08:22 +07:00 flash/Ringtones/Ring7.raw
106        495 Dec 29 2011 16:08:24 +07:00 flash/Ringtones/Ringlist.xml
107      10858 Dec 29 2011 16:08:24 +07:00 flash/Ringtones/Sax1.raw
108      14233 Dec 29 2011 16:08:24 +07:00 flash/Ringtones/Sax2.raw
109      16100 Dec 29 2011 16:08:24 +07:00 flash/Ringtones/Vibe.raw
110    8095286 Dec 29 2011 16:08:38 +07:00 flash/apps37sccp.1-3-4-0.bin
111    2942935 Dec 29 2011 16:08:44 +07:00 flash/apps31.8-5-3TH1-6.sbn
112    2935993 Dec 29 2011 16:08:48 +07:00 flash/apps42.8-5-3TH1-6.sbn
113    2935993 Dec 29 2011 16:08:54 +07:00 flash/apps45.8-5-3TH1-6.sbn
114    2935993 Dec 29 2011 16:09:00 +07:00 flash/apps75.8-5-3TH1-6.sbn
115    2933329 Dec 29 2011 16:09:06 +07:00 flash/apps41.8-5-3TH1-6.sbn
116    2933329 Dec 29 2011 16:09:12 +07:00 flash/apps70.8-5-3TH1-6.sbn
117    2599169 Dec 29 2011 16:09:16 +07:00 flash/APPSH-1.3.3.SBN
118    2591877 Dec 29 2011 16:09:22 +07:00 flash/APPS-1.3.3.SBN
119    2118620 Dec 29 2011 16:09:26 +07:00 flash/SYSH-1.3.3.SBN
120    2103754 Dec 29 2011 16:09:30 +07:00 flash/cvm70sccp.8-5-3TH1-6.sbn
121    2101414 Dec 29 2011 16:09:34 +07:00 flash/cvm41sccp.8-5-3TH1-6.sbn
122    2100804 Dec 29 2011 16:09:38 +07:00 flash/cvm45sccp.8-5-3TH1-6.sbn
123    2100554 Dec 29 2011 16:09:42 +07:00 flash/cvm75sccp.8-5-3TH1-6.sbn
124    2100286 Dec 29 2011 16:09:46 +07:00 flash/cvm31sccp.8-5-3TH1-6.sbn
125    2099070 Dec 29 2011 16:09:52 +07:00 flash/cvm42sccp.8-5-3TH1-6.sbn
126    2083047 Dec 29 2011 16:09:56 +07:00 flash/SYS-1.3.3.SBN
127    1939872 Dec 29 2011 16:10:00 +07:00 flash/WLANH-1.3.3.SBN
128    1906272 Dec 29 2011 16:10:04 +07:00 flash/SCCP69xx.8-5-3-0.zz
129    1892036 Dec 29 2011 16:10:08 +07:00 flash/GUIH-1.3.3.SBN
130    1887312 Dec 29 2011 16:10:12 +07:00 flash/jar75sccp.8-5-3TH1-6.sbn
131    1882934 Dec 29 2011 16:10:16 +07:00 flash/jar45sccp.8-5-3TH1-6.sbn
132    1848343 Dec 29 2011 16:10:20 +07:00 flash/GUI-1.3.3.SBN
133    1828410 Dec 29 2011 16:10:24 +07:00 flash/jar70sccp.8-5-3TH1-6.sbn
134    1756328 Dec 29 2011 16:10:28 +07:00 flash/jar42sccp.8-5-3TH1-6.sbn
135    1628021 Dec 29 2011 16:10:30 +07:00 flash/jar41sccp.8-5-3TH1-6.sbn
136    1616425 Dec 29 2011 16:10:34 +07:00 flash/jar31sccp.8-5-3TH1-6.sbn
137    1379535 Dec 29 2011 16:10:36 +07:00 flash/WLAN-1.3.3.SBN
138     939293 Dec 29 2011 16:10:38 +07:00 flash/TNUXH-1.3.3.SBN
139     896477 Dec 29 2011 16:10:40 +07:00 flash/TNUX-1.3.3.SBN
140     537925 Dec 29 2011 16:10:42 +07:00 flash/dsp41.8-5-3TH1-6.sbn
141     537925 Dec 29 2011 16:10:42 +07:00 flash/dsp70.8-5-3TH1-6.sbn
142     524969 Dec 29 2011 16:10:44 +07:00 flash/cnu45.8-5-3TH1-6.sbn
143     524917 Dec 29 2011 16:10:46 +07:00 flash/cnu42.8-5-3TH1-6.sbn
144     524876 Dec 29 2011 16:10:48 +07:00 flash/cnu75.8-5-3TH1-6.sbn
145     503753 Dec 29 2011 16:10:48 +07:00 flash/cnu31.8-5-3TH1-6.sbn
146     500084 Dec 29 2011 16:10:50 +07:00 flash/cnu70.8-5-3TH1-6.sbn
147     499644 Dec 29 2011 16:10:50 +07:00 flash/cnu41.8-5-3TH1-6.sbn
148     496521 Dec 29 2011 16:10:52 +07:00 flash/music-on-hold.au
149     340615 Dec 29 2011 16:10:54 +07:00 flash/dsp31.8-5-3TH1-6.sbn
150     340615 Dec 29 2011 16:10:54 +07:00 flash/dsp42.8-5-3TH1-6.sbn
151     340615 Dec 29 2011 16:10:56 +07:00 flash/dsp45.8-5-3TH1-6.sbn
152     340615 Dec 29 2011 16:10:56 +07:00 flash/dsp75.8-5-3TH1-6.sbn
153     264368 Dec 29 2011 16:10:58 +07:00 flash/DSP69xx.0-0-0-3.zz
154     165355 Dec 29 2011 16:10:58 +07:00 flash/B016-1-0-3.SBN
155     146463 Dec 29 2011 16:10:58 +07:00 flash/B015-1-0-3.SBN
156      44896 Dec 29 2011 16:11:00 +07:00 flash/BOOT69xx.0-0-0-14.zz
157      11601 Dec 29 2011 16:11:00 +07:00 flash/CME-8-0-Full-Readme-v.1.0.txt
158       5134 Dec 29 2011 16:11:00 +07:00 flash/7970-71-75-Background-readme-v1.txt
159       1916 Dec 29 2011 16:11:00 +07:00 flash/MISC-1.3.3.SBN
160          0 Dec 29 2011 09:44:30 +07:00 flash/GUI
161       1029 Dec 29 2011 16:39:40 +07:00 CiscoLogo.gif
162       1019 Dec 29 2011 16:39:40 +07:00 CME_GUI_README.TXT
163        953 Dec 29 2011 16:39:40 +07:00 Delete.gif
164      16344 Dec 29 2011 16:39:40 +07:00 dom.js
165        864 Dec 29 2011 16:39:40 +07:00 downarrow.gif
166       6315 Dec 29 2011 16:39:42 +07:00 ephone_admin.html
167       4558 Dec 29 2011 16:39:42 +07:00 logohome.gif
168       3978 Dec 29 2011 16:39:42 +07:00 normal_user.html
169      78428 Dec 29 2011 16:39:42 +07:00 normal_user.js
170       1347 Dec 29 2011 16:39:42 +07:00 Plus.gif
171        843 Dec 29 2011 16:39:44 +07:00 sxiconad.gif
172        174 Dec 29 2011 16:39:44 +07:00 Tab.gif
173       2496 Dec 29 2011 16:39:44 +07:00 telephony_service.html
174        870 Dec 29 2011 16:39:44 +07:00 uparrow.gif
175      10230 Dec 29 2011 16:39:44 +07:00 xml-test.html
176        481 Dec 28 2011 13:05:32 +07:00 SCCP69xx.9-2-1-0.loads
177      45308 Dec 28 2011 13:05:58 +07:00 BOOT69xx.0-0-0-14.zz.sgn
178     224952 Dec 28 2011 13:06:24 +07:00 DSP69xx.0-0-0-8.zz.sgn
179    2725992 Dec 28 2011 13:06:52 +07:00 SCCP69xx.9-2-1-0.zz.sgn
180       3412 Dec 29 2011 16:39:46 +07:00 xml.template
182     177314 Feb 17 2012 01:15:36 +07:00 crashinfo_20120217-011536-ict
183     237859 Mar 8 2012 15:54:52 +07:00 crashinfo_20120308-155452-ict
184     214488 Mar 28 2012 05:00:24 +07:00 crashinfo_20120328-050025-ict
185     216265 Apr 19 2012 08:43:58 +07:00 crashinfo_20120419-084359-ict
186        720 Dec 12 2012 15:57:10 +07:00 vlan.dat
187     215451 May 30 2012 23:40:52 +07:00 crashinfo_20120530-234053-ict
188     221236 Jun 21 2012 00:02:30 +07:00 crashinfo_20120621-000230-ict
189     263610 Jul 19 2012 17:10:52 +07:00 crashinfo_20120719-171052-ict
190      17026 Dec 27 2012 11:01:50 +07:00 pre_autosec.cfg
67989504 bytes available (192163840 bytes used)
4. sh
(config-ephone)#type ?
  12SP    12SP+ and 30VIP phones
  6901    Cisco IP Phone 6901
  6911    Cisco IP Phone 6911
  6921    Cisco IP Phone 6921
  6941    Cisco IP Phone 6941
  6945    Cisco IP Phone 6945
  6961    Cisco IP Phone 6961
  7902    Cisco IP Phone 7902
  7905    Cisco IP Phone 7905
  7906    Cisco IP Phone 7906
  7910    Cisco IP Phone 7910
  7911    Cisco IP Phone 7911
  7912    Cisco IP Phone 7912
  7920    Cisco IP Phone 7920
  7921    Cisco IP Phone 7921
  7925    Cisco IP Phone 7925
  7926    Cisco IP Phone 7926
  7931    Cisco IP Phone 7931
  7935    Cisco IP Conference Station 7935
  7936    Cisco IP Phone 7936
  7937    Cisco IP Conference Station 7937
  7940    Cisco IP Phone 7940
  7941    Cisco IP Phone 7941
  7941GE  Cisco IP Phone 7941GE
  7942    Cisco IP Phone 7942
  7945    Cisco IP Phone 7945
  7960    Cisco IP Phone 7960
  7961    Cisco IP Phone 7961
  7961GE  Cisco IP Phone 7961GE
  7962    Cisco IP Phone 7962
  7965    Cisco IP Phone 7965
  7970    Cisco IP Phone 7970
  7971    Cisco IP Phone 7971
  7975    Cisco IP Phone 7975
  7985    Cisco IP Phone 7985
  8941    Cisco IP Phone 8941
  8945    Cisco IP Phone 8945
  CIPC    Cisco IP Communicator
  IP-STE  SCCP IP STE
  anl     SCCP Gateway (AN)
  ata     ATA  phone emulation for analog phone
  bri     SCCP Gateway (BR)
I should go to next step ?
Thank You
Sarawut Sampaothong
5 Replies 5
Jorge Armijo
Level 4
Level 4
Pakorn,
3905 is a SIP Phone only. You'll need to configure "voice register global"
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f33eb.shtml
That's the reason you can't see type 3905 unger ephone configuration.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jorge,
I have a query in my mind /always confused regarding the CME licneses while doing upgrade.
While doing upgrade do we need to follow any pre-requistie for CME licenses even though they are honour based/Paper licenses
Please advise.
regds,
aman
Hi Jorge,
Voice Register Global Parameters Configuration
 mode cme
!--- Set Cisco IOS SIP registrar to CME mode.
 source-address 192.168.10.1 port 5060
!--- Set the source address for phone registration.
 max-dn 20
!--- Set max extensions.
 max-pool 10
!--- Set max phones.
 load 7970 SIP7 SIP70.8-2-1S
!--- Specify phone loads for each phone type.
 load 3911 SIP3951.8-0-2-9
 authenticate register
!--- Set authentication for phone registration.
 authenticate realm cisco.com
 tftp-path flash:
!--- Specify path for tftp files.
 create profile
!--- Create configuration files for all phones.
 dialplan-pattern 1 4085251... extension-length 3
!--- Configure dial-plan pattern for the system.
step . 1  I uplaod  APP3905.9-2-1-0.zz  and CP3905.9-2-1-0.loads to flash .
step . 2
I config
(config-register-global)#load ?
  3905       Select the firmware load file for 3905
  3911       Select the firmware load file for 3911
  3951       Select the firmware load file for 3951
  6901       Select the firmware load file for 6901
  6911       Select the firmware load file for 6911
  6921       Select the firmware load file for 6921
  6941       Select the firmware load file for 6941
  6945       Select the firmware load file for 6945
  6961       Select the firmware load file for 6961
  7905       Select the firmware load file for 7905
  7906       Select the firmware load file for TNP 7906 phone
  7911       Select the firmware load file for TNP 7911 phone
  7912       Select the firmware load file for 7912
  7941       Select the firmware load file for TNP 7941 phones
  7941GE     Select the firmware load file for TNP 7941GE phones
  7942       Select the firmware load file for TNP 7942 phones
  7945       Select the firmware load file for TNP 7945 phones
  7960-7940  Select the firmware load file for Telecaster 7960 & 7940 phones
  7961       Select the firmware load file for TNP 7961 phones
  7961GE     Select the firmware load file for TNP 7961GE phones
  7962       Select the firmware load file for TNP 7962 phones
  7965       Select the firmware load file for TNP 7965 phones
  7970       Select the firmware load file for TNP 7970 phones
  7971       Select the firmware load file for TNP 7971 phones
  7975       Select the firmware load file for TNP 7975 phones
  8941       Select the firmware load file for 8941 phones
  8945       Select the firmware load file for 8945 phones
  8961       Select the firmware load file for RT 8961 phones
  9951       Select the firmware load file for RT 9951 phones
  9971       Select the firmware load file for RT 9971 phones
  ATA        Select the firmware load file for ATA
  ATA-187    Select the firmware load file for ATA-187
Netbright_Router(config-register-global)#load 3905 ?
  WORD  firmware filename for 3905 [without .loads]
(config-register-global)#load 3905 CP3905.9-2-1-0
step 3 . all step Voice Register Global
Thank You
Sarawut Sampaothong
Yes, upload the files to flash, then configure the tftp bind commands and let the phone download the files.
Jorge Armijo
Pakorn Homhual
Hi Jorge,
I upload the files to flash. and conft tftp-path flash. I see problem error with sipphone.
sh_voice_rege_global
sh_flash
sh_regie_static
Thank You
Pakorn
