i need know frequency on fxo trunk
i have problem on fxo gateway
when i  make call out side on pstn the ip phone make connect direct and billing server make bill the call
i need know how to frequency on ksa
frquency ring out
frequency outside the mobile is close
frequency wrong number
frequency disconnect signal
  • IP Telephony
1 ACCEPTED SOLUTION
Re: i need know frequency on fxo trunk
Hello Haytham
1-Can you use the below link to get all required tones?.
http://www.3amsystems.com/wireline/tone-search.htm?
2- Please find the below :-
voice class custom-cptone STC
dualtone busy
  frequency 425 425
  cadence 500 500
dualtone ringback
  frequency 425 425
  cadence 1000 4000
dualtone reorder
  frequency 425 425
  cadence 250 250
dualtone out-of-service
  frequency 425 425
  cadence 320 320
dualtone disconnect
  frequency 425 425
  cadence 500 500
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone STC
supervisory dualtone-detect-params 2
no battery-reversal
cptone SA
timeouts initial 5
timeouts interdigit 3
timeouts call-disconnect 3
timeouts ringing 5
timeouts wait-release 1
timing hookflash-out 50
timing guard-out 300
timing sup-disconnect 300
connection plar opx 8800
impedance complex2
caller-id enable
Thank you
Please rate all useful information
Hello Haytham
dualtone busy
  frequency 425 425
  cadence 500 500
dualtone ringback
  frequency 425 425
  cadence 1000 4000
dualtone reorder
  frequency 425 425
  cadence 250 250
  frequency 425 425
  cadence 320 320
dualtone disconnect
  frequency 425 425
  cadence 500 500
voice-port 0/0/0
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
caller-id enable
Thank you
Try with fxo port empty configuration
add
cptone [your country]
It should work normall
You'll need frequency if you face fxo disconnect issue
Haitham
dear eng islam
thanks for help
when call come on router directly remove number 9 make connect direct same after change confiuration
if you found problem tell me
this configuration on router
! Last configuration change at 20:33:40 UTC Tue Oct 29 2013
version 15.2
hostname voicegateway1
boot-start-marker
boot-end-marker
enable secret 5 $1$R/VE$zJggecBnCmnKxPqfgRvU71
no aaa new-model
no ipv6 cef
ip cef
trunk group VIC2-4FXO
voice-card 0
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
dualtone busy
  frequency 425 425
  cadence 500 500
dualtone ringback
  frequency 425 425
  cadence 1000 4000
dualtone reorder
  frequency 425 425
  cadence 250 250
  frequency 425 425
  cadence 320 320
dualtone disconnect
  frequency 425 425
  cadence 500 500
license udi pid CISCO2911/K9 sn FGL160610FE
hw-module pvdm 0/0
hw-module sm 1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.16.12.3 255.255.252.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 172.16.12.3
interface Serial0/3/0
no ip address
shutdown
clock rate 2000000
interface Serial0/3/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.12.254
control-plane
voice-port 0/0/0
trunk-group VIC2-4FXO
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
connection plar opx 8400
impedance complex2
description line 8187887
caller-id enable
caller-id alerting dsp-pre-allocate
voice-port 0/0/1
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
description line 8187778
caller-id enable
voice-port 0/0/2
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
description line 8187777
caller-id enable
voice-port 0/0/3
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
description line 8189001
caller-id enable
voice-port 0/1/0
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
description line 8189009
caller-id enable
voice-port 0/1/1
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
description line 8188007
caller-id enable
voice-port 0/1/2
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
description line 8188006
caller-id enable
voice-port 0/1/3
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
description line 8188004
caller-id enable
voice-port 0/2/0
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
description line 8188002
caller-id enable
voice-port 0/2/1
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
caller-id enable
voice-port 0/2/2
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
caller-id enable
voice-port 0/2/3
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
caller-id enable
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
voice-port 1/0/8
no battery-reversal
cptone SA
timeouts initial 5
timeouts ringing 5
impedance complex2
caller-id enable
voice-port 1/0/9
voice-port 1/0/10
voice-port 1/0/11
voice-port 1/0/12
voice-port 1/0/13
voice-port 1/0/16
voice-port 1/0/17
voice-port 1/0/18
voice-port 1/0/19
voice-port 1/0/20
voice-port 1/0/21
mgcp profile default
dial-peer voice 3 voip
description Local extensions
preference 1
destination-pattern ....
session target ipv4:172.16.12.11
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 4 voip
session target ipv4:172.16.12.12
voice-class codec 1
voice-class h323 1
no vad
dial-peer voice 51 pots
trunkgroup VIC2-4FXO
destination-pattern 9[2-8]......
forward-digits 7
dial-peer voice 52 pots
destination-pattern 90[123467].......
forward-digits 10
dial-peer voice 53 pots
destination-pattern 905........
forward-digits 10
dial-peer voice 54 pots
destination-pattern 800.......
forward-digits 10
dial-peer voice 55 pots
destination-pattern 9200.....
forward-digits 9
dial-peer voice 56 pots
destination-pattern 99..
forward-digits 3
dial-peer voice 57 pots
destination-pattern 00T
no digit-strip
forward-digits all
gateway
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password terminal
login
transport input all
scheduler allocate 20000 1000
eng islam
order not complete
i need order
voice class dualtone-detect-params 2
I would try the cptone suggestion for your country. If that doesn't work you might need to do a PCM capture and listen to it in audacity to extract the exact frequencies, although it's rarely needed.
Making the World a better place, one call at a time.
eng islam
order is working
but frequency out-off service not correct
876
