I need physical connection information for 7960 IP phone
Hi All,
The following components ready for the IP phone 7960. This is to test the IP phone 7960.
1. 2600 router
2. WIC-1DSU-T1 card
3. WS-C3548-xl-en (PoE Switch)
4. 7960 IP phone (15 nos.)
I also referred http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
I need information on physical port connectivity.
> What port do I need to use to connect Switch and Router?
> Do I need any specific card to complete this connection?
> Do I need to use WIC-1DSU-T1 card?
Thank you
Re: I need physical connection information for 7960 IP phone
Is this for Call manager express that you want to run at home?
connect the switch to the router in such a way that the phones (whatever vlan you put them in) can reach it, full duplex, 100?
more information as to what setup you are lookuing for
Please remember to rate useful posts, by clicking on the stars below.
Do I need WIC-1DSU-T1 card?
I have only one Ethernet port on 2600 series router. I need to use one for the PoW switch+ ip phone and one more for the Existing LAN connection. How can I do this?
Yes, I also Look for Call MAnager Express.
Thank you,
Hall of Fame Super Red
Hi Siva,
You will not require the WIC-1DSU-T1 card in your current configuration :)
Have a look at the requirements/uses of this card and note that it would not come into play for testing the 7960's.
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a0080093d70.shtml
Hope this helps!
Rob
Rob, Since I have only one ethernet port on 2600 series router. I have to connect the Switch + Ip phone and also to my existing 800 series router. How can I do this, do i need any additional card?
Thank you,
Rob, Waht card can i use to connect 2600 to 800 and PoE switch?
Hi Siva,
Normally when we are building an isolated lab test setup (which i believe you are doing :) We would connect all the devices to the 3548 to simulate an actual network design. Make sense?
Hope this helps!
Rob
Rob,
IP phone repeatly display the following message,
1. Configuring CM
2. Opening 10.163.235.1
Thank you,
Can anyone let me know the issue please? Is that looking for Call manger software from the router? if so, why call manager software is not available in 2610 router.
show telephony-service is not recognised by 2610 router to check for CME software.
Thanks in advance.
157
