I need to develop a Cisco VoIP Monitoring solution. What model/series should i buy?
I work for a software company, and we are working towards building a Cisco VoIP solution.
I need to know what model of Cisco VoIP do i need to buy so my developers can use it to develop support for all major flavors of VoIP.
As per my research so far, i need to support following series:
1) Cisco 300/500 series (for SMBs)
2) Cisco Business Edition 3000/5000/6000
3) Cisco Unified Communication manager.
I don't want to have to buy one of all the series.
Please suggest.
AJ
Everyone's tags (2)
Blue
Hi AJ,
The product selectoin is based on your
1) Budget
2) Number of sites
3) Number of users....
CUCM for large deployment. CUCMBE is for Medium range and SMBs are for small to medium business.
Aoart from this you will need Cisco gateways if you want PSTN connectivity , Conference resources and transcoder if you want conferencing solution, also you will need Cisco IP phones as end points.
Let me know if you need any thing else.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
Thanks for the reply.
Budget in not a concern.
I need to buy this solution as a part of my QA Lab, and this is solely meant for my developers to code the monitoring solution.
To answer your questions,
Let's assume i need:
a) 1 site
b) 5 users (This involves a mix of hard-phones and soft-phones).
-AJ
Blue
You can go for CUCUMBE, CUCUMBE is combination of CUCM/CUC/UCCX product in one product. take one 39XX gateway for PSTN connectivity and go with some latest hard ip phone and CIPC as sft phone.
regards
Ronak Patel
Rate helpful posts.
569
