I need to know how many PRI's my 2620 can handle
I currently have a 2620 with two pri's installed in it. I need to add another vwic to support 10 more lines.
Will this router handle it?
Can someone give me a link to a doc on how i can tell this about my router and others for the future?
Hall of Fame Super Gold
Re: I need to know how many PRI's my 2620 can handle
Although it may work with an AIM-VOICE-30, seems a bit too much for a 2600 anyway. a 28xx or an as 5350 would be a better choice.
hope this helps, please rate post if it does!
Silver
Hey D0nprintup,
Have a read through this paper:
<http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a0080100688.shtml>
I have skimmed over it and it would appear the the HDV module slots will be your only option. So if two is the max - then this is going to be your limit.
There's also this one:
<http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a008039c333.shtml>
And finally:
<http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/nm_inst/nm-doc/ovrnetm.htm>
hth,
Ajaz
Actually as I mentioned above a vwic or vwic2 would work if you also add aim-voice-30:
http://cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800f9d37.shtml#c2600wic
But I woulr replace for another router anyway as the aim-voice-30 is older, limited technology.
100
