I need to setup 7800 Series IP Phones in the CUCM 8.6.2 which by default are not support but will work after install the software. Anyone have document from Cisco as I remember I seen once before.
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: I need to setup 7800 Series IP Phones in the CUCM 8.6.2 whic
Hi Ali,
I'll just add this reference to the good tips from my friend Manish (+5)
Support for the 7800 series in CUCM 8.6.2 was first added with this
Device Pack;
Cisco Unified Communications Manager
Device Package 8.6(2)(24104-1)Release Notes
Cisco Unified Communications Manager Device Package Release 8.6(2)
adds support for the Cisco IP Phones
7821, 7841, and 7861 running SIP firmware release 10.1(1).
The steps are in this doc
http://www.cisco.com/web/software/282074299/107528/cmterm-devicepack-8.6.2.24104-1_Readme.pdf
You might as well install the latest 8.6.2 Device pack
cmterm-devicepack8.6.2.24112-1.cop.sgn
Cheers!
Rob
"Seek it out and ye shall find  "
- OneRepublic
If some one have steps that will save my time too. thanks
Hi Ali,
Please check this link
https://supportforums.cisco.com/thread/2256077
Manish
Hi Ali,
Device Pack;
Cheers!
Rob
- OneRepublic
Thanks for adding some more useful info to this post Rob [+5] .
Manish
Thanks Guys
318
